"Oil Maint Reqd"
I just had an oil change but not with Lexus, for some reason it doesnt reset or maybe Lexus has to reset the computer but does anyone know how to reset it without going to Lexus? It'll be a waste of time to go to Lexus to reset the computer. I'm going back to Lexus for the next oil change, if im not wrong the last oil change I had with lexus gave me 5k before the next oil change and this oil change only has 3k.
If you have navi reset under the info button, oil change.
Press the start button without stepping on the brake so the car turns on, and hold down the trip button on the cluster. You will see the odometer show ----- and that shows you just reset it for 5k to remind you to change your oil. It's also in the DIY section in your owner's manual.
The advice on the other thread didnt work.
"Originally Posted by Zephyr
Press the start button without stepping on the brake so the car turns on, and hold down the trip button on the cluster. You will see the odometer show ----- and that shows you just reset it for 5k to remind you to change your oil. It's also in the DIY section in your owner's manual." <--- Worked.
Thanks again.
Thanks again.
