Navigation says the destination 200 to 300 fts before the target.
my navigation says the destination (not sure exactly what it says, but something like you have reached your destination, guidaince will now suspend) 200 to 300 fts before the target. Is this happening to anyone?
Yeah, it happens to me too, I think it's just to let you know it's right there so you don't pass it...
i think there's an acceptable degree of fluctuation with the information also. if you put it in "address view" (with compass no map and it tells you the street address you're at while you're driving), its off by a couple hundred feet.
Depending on how well/many satellites are acquired by the system the accuracy will vary. If you look up in the top left corner by the north arrow it will tell how accurate the system is working. If you loose the signal you will just get an arrow. On most of the handheld units they use what is called a WAAS (Wide Area Augmentation System) system that uses a network of towers that receive GPS signals and transmit a corrected signal by beacon transmitters I've seen less then 9 foot accuracy readings. I don't think the car nav systems use WAAS.
Koz
Koz
Koz
Koz
And that's not exactly how waas works: http://www.garmin.com/aboutGPS/waas.html
