OEM Front Lip Install Question
Hello,
I just got my front lip from Sewell Lexus, I have a question regarding the drill bit size. On the installation instructions it says o3 and o12 does that mean 3mm and 12mm?
Also, for those who have installed the front lip any advice or pointers would be appreciated!![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Thanks,
TJ
Thanks,
TJ
i think those are in mm, you're right. i actually used smaller bit size first then planned on increasing the size if needed. luckily, it fitted just fine even with the smaller holes/slots.
only advice to you is be patient man. i got frustrated too when the front lip had a gap from the bumper around the area where it curves. i left for a few minutes and tried fitting again afterwards.
![](http://members.***.net/abukenos/is350_5.jpg)
