Creaking/Squeaking noises!
Hey, I have 2 gripes about my IS350.
1.When Im driving fast or going on rougher roads, there is something that keeps rattling in the back seat. Anyone know what that is? I asked my friend sitting in the back seat to look and he was looking all over and could not find out what the rattling noise was about. It seems to be behind the rear seats somewhere. It sounds like plastic'y sounds. I cant explain what it is.
2. And now about the the creaking noise.
When I go off a driveway onto a curb, or out of a parking lot, I can hear my roof creak or squeak. I am assuming that pressure is being put to the roof my my car which causes it to squeak. It is extremely annoying. Pleaes someone help!
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
I have the same rattling noise in the back, sounds like it's near the back
window. The noise is very subtle, not enough for me to complain. I was thinking
it could be the rear sunshade. Tested, wasn't that. There are so many things
nice about this car, I don't want to muck with a small thing like that. If it
gets worse then I might consider. Is there such a thing as a 100% perfect car?
I've had a lot of sounds (too many for a crappy car) which I shouldn't have in a Lexus at all. The fit-and-finish is the worst I've seen a car in a long time. Rattles/squeeks coming from the dashboard and center console. My doors rattle and make annoying sounds. I've also got sounds coming from the back of the car just like it was described previously. You'd think I was driving a Ford with these kinds of sounds. I'm extremely disappointed in that aspect of the car. Everything else otherwise is great. It's just the ^&%$&%@$@ sounds that are killing me.
It's also a pain in the *** to get these items looked at. The streets by the dealer are very good so you don't hear much... I hate having to bring the car in for this stuff. A Lexus should just not have these problems AT ALL.
Coming from my previous cars (2 g35's), I understand how those rattles can drive you sterile. I think I had good karma coming after those rattle traps.
Good luck.
I recieved this PM courtesy of XVTEC. Thank you. Hopefully his problem is the same as ours.
GOOD MORNING,
I THINK I CAN HELP. MY NEW IS MADE A VERY SIMILAR NOISE AFTER BEING PARKED IN THE SUN [SO. FLORIDA IS HOT!].IT TOOK JM LEXUS IN COCONUT CREEK 2 WEEKS TO FIGURE IT OUT AFTER FINALLY CALLING FOR TECH ASSISTANCE, IT WAS THE REAR WINDSHIELD GLASS RUBBING ON PLASTIC SPACERS THAT CENTER THE GLASS DURING INSTALLATION AT THE FACTORY.SINCE THAT DAY I HAVE NEVER HEARD ANOTHER SOUND
GOOD MORNING,
The squeaky sound around the sun roof is actually the sun roof weather seal rubbing against the body. Apply a rubber conditioner on the seal and no more squeak for about 2-3mons.(chasis not stiff)
Another creaking noise around the dash and windsheild is the dash rubbing the windsheild. I use black shock. Cut and fold . Wedge between. Works good.
Rattle behind seat is actually inside upper drivers door panel, near b-piller.(seat belt).
If you think the is350 rides jittery, it does.
Wheelbase biggest factor and suspension built for heavier car GS. Try different tires. It will also lessen aglinment pull. Am I Trippin? Peace!
Have you ever took your vehicle for repair and end up with a new problem?
Personaly, I fix it myself. Even the first oil change. I decline free car wash from the dealer.
However if it something like the ecu is defective then I have no choice but let Flat rate mechanics touch my car.
If youre under 15k miles dealers get paid to address any noise or adjustments. Just make sure You request only senior techs not a rookie learning.
Liquid Bra Champion
Goodluck! Do you ask for references as well.
My 350 creaks and pops underneath when I back out of the driveway and when I hit bumps. I took it to the dealer and the service rep and I drove over to Infinity and drove it up and down there ramp. There are no bumps around the dealership. We got it to do it only slightly. He said it was the brakes and that all Lexus's do it after about 5k miles. I took it to brake check and they told me that was bs. I'm not sure what it is. Any one else have this problem?
i have this really anoying noise comming from what seems the glove box or right over where the passengers feet would be... its very subtle but i just got the car last thursday and it only has 1000 miles on it... anyone know what it could be?
