Is there a difference between 250 & 350...
When bad outside air (e.g. diesel exhaust) is detected, the climate control automatically switches to recirculate mode.
(mod idea: hook it up backwards so that when a passenger releases a squeeker, the climate control automatically switches to fresh air, and if really strong, opens the windows. )
Similarly equipped 250's and 350's are identical in every way except for:
1. Engine
2. Brakes
This means, other than engine or brakes, if it's available or standard on the 350 it's also available or standard on the 250.
For example: The power tilt and telescopic steering wheel is part of the Luxury or sport package. It doesnt matter if it's a 250 or a 350 because the package is available on both cars. All factory options are available on both cars.
1. Engine
2. Brakes
the 350 has ventilated REAR discs! didn't list that anywhere on the website, only when i went in to buy my 250 did i discover that the 250 didn't.
on non-nav 250, the manual says that the "filter" button, when pushed, will recirculate and remove pollen from the air in the cabin....
i don't know how they figure smog = pollen, i guess the marketing dept. massages this aspect up a bit. smog is detected (on 350), recirculate air, remove pollen (technically). i didn't know cars emit pollen!?
