Changing fog light bulbs?
Can anyone tell me how to change the 9006 foglight bulbs on the 2006 IS250 because the manualbook doesn't say anything about fogs~ thanks!
2IS OG
For quicker answers, click the "Search this Thread" button at the top of the thread listings A simple search will reveal threads like the following that have all the info you could want on this subject:
https://www.clublexus.com/forums/sho...+light+install
Javier
Javier
changing foglamp bulbs are quite easy. For each side.. remove all clips from the fender liner.
2 of them should be the simple turn type is a must.
2 more 10MM screws are optional. I removed them for more work space.
The first screw is on the bottom of the Fender Liner.
The second screw is on the wheel well.
Remember to turn the steering wheel all the way to the right if you want to change the Left Bulb. This is vise versa when you want to change the Right bulb. Turn all the way to the left.
Then I would add masking tape to the painted edge of the bumper.. then peel it out.
Once you peeled it out, you should have access to the bulb.
It is easy. Shouldnt take you more then 5-10 each side.
Refer to the previous post. I think it is a pictorial.
