ECT Snow vs ECT PWR data logs show NO difference in power
Old 10-10-06, 01:54 PM
Gernby
Gernby's Avatar
I don't think the variation in throttle angle has anything to do with VDIM. Why would VDIM cause the same change in throttle in 3rd gear as it does in 1st? I think it has something to do with VVTi.
Old 10-10-06, 02:19 PM
jman-is350
jman-is350's Avatar
Great work.
Old 10-10-06, 04:55 PM
clubfoot
clubfoot's Avatar
Variable Valve Timing with Inteligence?! Maximising air flow to match the changes in valve timing? I guess it could be possible. I was more thinking along the lines that at WOT the ECU is programmed to keep the shifts as smooth as possible, (read Lexus), keeping traction at its max without breaking the tires. I've never driven my car without the nannies so,...you would probably know more about this from experience.
Keep the info coming.
Old 10-11-06, 10:32 AM
cdeslandes
cdeslandes's Avatar
ECT/Snow modes just do two things:
1) Change the shift points;
2) Change the throttle sensitivity at partial throttle.
If you floor it, you get the full 306 ponnies in any mode.
Your charts just confirmed this.
FLYCT
11-04-19 07:10 PM
Caddydaddy
02-21-18 10:53 AM
UnderCover
11-14-16 04:38 PM
anesthesia
03-03-14 08:46 AM
CAMAracer
08-09-08 01:32 PM
Quick Reply: ECT Snow vs ECT PWR data logs show NO difference in power
