Replacing Stock Bulb with White Bulb
I can't seem to find a thread on replacing stock headlight bulbs with white bulbs. Can someone point me to that direction or explain to me how this is done. I can't find my Lexus manual. And what white bulbs do you recommend?
TIA !
TIA !
See website: http://store.racinglab.com/pixtwhplhhal3.html
^ From the link: "12V55W = 110 Watt"
What does it mean?
If I recall my basic electronic course correctly, Power = Voltage * Current
If PIAA bulb put out twice as much light (claimed), then it will need that extra boost of power from somewhere. The only way is to draw more current.
Standard halogen draws around = 55 watt / 12 volt = 4.6 Amp
PIAA bulb draws around = 110 watt / 12 volt = 9.2 Amp.
That is one heck of *continuous* current draw for the OEM wiring.
Will some parts of the wiring (i.e wire, harness, light switch inside the steering) be burnt sooner or later? ...
Please correct me if I am wrong
What does it mean?
smooche
12-16-04 03:46 AM
