rattles by my left ear
Rattle by my left ear. Something in the driver door is rattling making me nuts!!!
I think that it is the window because when it is opened/cracked noise is gone. Anyone have the same problem? I checked all Service Bullentin and nothing on this problem.
Yup...
I recently took a 5 hour road trip, and halfway thru I heard a rattling by my left ear as well... kinda like it was coming from where the seat belt comes out over my shoulder. However, I noticed that when I pushed my elbow into the drivers door, the rattle stopped, so maybe it does have something to do with the window?
I have the same but occurs occasionally. One time I pushed on the B pillar pretty hard and it went away. But it seems like its from the door though. One speculation - the same thing happened with my BMW. When you crack open the window the noise goes away - it was the rubber door seals moving against the body of the car that caused it. Lubricating it with armor all or silicon spray helped for a few months. I wonder if that is also happened with our cars.
I had the same rattle in my 06 IS350 until I put the head rest all the way down. It really sounded like it was coming from the B pillar or the door, but in my case having the head rest all the way up caused it to rattle around it it's track.
Tech Info Resource
Mine stops with slight outward pressure on the driver's side window.
I have the exact same metallic rattle. In my case it is in the door, in fact I have taken it in for the problem. The dealer installed felt all over the inside of the door, still have the rattle.....If I push out on the rear top part of the door panel with my left elbow it goes away. If I pull (unclip) the door panel while Im driving I can still hear it! It driving me crazy as well.....If anyone can shed some light on this one it would be awsome!!!
I fixed the rattle!!!!
So I made some time today to deal with my rattle. Here's what I did:
1.) Removed the door panel. I did not take pictures, but Ill do my best to instruct you how: a.) I used a flat screwdriver to gently lift up the window switch panel, and interior door handle/lock cover to reveal the screws that hold the door panel in. No force is required in either case. b.)pulled on the panel starting with the top to unclip the panel from the door, being careful to not pull too hard or far because there are wires attached to the panel for the tweeter and door light. c.) Unclipped door light and tweeter wires.
2.) Removed the window strip from the door, felted the metal clips that hold it down.
3.) The panel has a white nylon fabric on the inside, I peeled it up to inspect what the hell was under it (nothing) but my rattle was the platic crap under it. So I got some 3M spray glue and lightly sprayed the area to put the nylon fabric back down.
4.) put it back together the way I found everything...now the rattle is gone.
To be honest I dont know if I found the actual cause of the rattle, but by merely disassembling everything, and reassembeling it, I believe that is what killed the rattle (THANK GOD!)
Hope this helps you guys.....I might add I DID have lexus look at this problem and they were unable to fix it in one day, they wanted me to leave the car overnight, and at the time this was not an option.....its been a few months since then, and this thread reminded me of how annoying the rattle is....so thanks thread starter for reminding me....now Im going to drive the car w/o music for a while to enjoy the silence...!
Yup...
I just recently got mines fixed for the same issues. The noise that you are experiencing is from the B pillar seat belt. Take it to dealer and they will take care of it.
....my rattle is BACK!
I read a while ago that there was a rattle in the B-pillar but in my case (and with a few other's here apparently) the problem is in the door itself, that is why when pressure is applied to the door/window, the rattle stops....
.....I would also like to add that my rattle HAS returned!! So if anyone is successful in isolating this rattle please let us know....I will probably have some time in the next couple days to take it apart again, and see if I can isolate it...
