Money burning a hole for mods... which ones?
It doesn't appear that there are a lot of us out here buying mods for the IS350. I've been following for a while now trying to determine which exhaust and which intake are "the best". What I'm really looking for is some real independant dyno's that have been done testing before/after for the various intakes/exhausts. Maybe my searching sucks, or there are really only a couple people that have done any dyno runs. I struggle with spending $1000-$1800 for an intake/ehaust setup with a gain of 5hp (+/-). But I'm certainly willing to fork over the dough for some proven performance parts. Lord knows I've spend upwards of $10,000 on mods on my previous toys!
As always, the more info the better!
- I can't find any dynos on the LMS exhaust.
- Tanabe appears to be, what, 3hp? Or is it 7hp?
- Is the K&N Typhoon kit really 11.27hp at the wheels? Hopup wouldn't say if it was at the wheels or the crank, and they don't have any dyno graphs.
- What about the LMS intake? Any real numbers on it?
- Are there any other exhausts or intakes that I should consider that someone has real numbers on?
2IS OG
Weedo, yes your searching does suck because there are quite a few intake/exhaust choices available for the 2IS... just kidding!
Good luck with that one...
Good luck with that one, too...
You certainly don't need to spend that much. Check out this thread and you'll see almost every possible intake/exhaust comination availalble for the 2IS.
https://www.clublexus.com/forums/sho...d.php?t=235313
Hope this helps,
Javier
Hope this helps,
Javier
Weedo, yes your searching does suck because there are quite a few intake/exhaust choices available for the 2IS... just kidding! Good luck with that one...
Hope this helps,
Javier
Hope this helps,
Javier
Helps a little bit, but really just shows that no one has spent $60 and and 30 minutes to dyno test any of the products. I'm sure some of us have, but the only ones I recall seeing showed little to no gains.
Another options is to show some back-to-back Gtech times or actual 1/4 mile times. Intakes are notorious for putting out 0hp on the dyno yet can yeild, say, .1 in the quarter mile.
I dyno'd my '06 SRT-8 before and after the exhaust install and it was around 21rwhp/20rwtq. Others got similar gains. I'm just surprised I'm not seeing any exhausts being tested with proven gains. LMS hasn't responded to any of my questions regarding dyno numbers on their exhaust, or even how it works as far as throwing codes with no cats. If the LMS puts down 20rwhp and the Tanabe is 5rwhp, that will certainly help my decision... I haven't seen any dyno numbers on the LMS intake either.
11 Second Club
Save your money and take a vacation instead. None of the intakes will make much of a difference and if you are itching to buy an intake the JOEZ intake pipe is what I recommend. Works for me plain and simple as this is my only mod and it hasn't disappointed me yet. If I were to get an exhaust I really would have to have money burning a hole in my pocket. Most run between $650-$1400 and give little gain and have minimal weight savings. HKS through the dealers seems to be the most expensive, but from what I have heard sounds very good. Would love to see someone "third party" dyno before and after the exhaust install.
11 Second Club
https://www.clublexus.com/forums/sho...d.php?t=201659
In the end most of the $$$$$ spent on an exhaust system will be for nothing other than the satisfaction is setting your car apart from the crowd.....at least some of the crowd
Adding a new exhaust to a modern car for a power gain you can feel is the biggest waste of $$$$$$$$ there is next to drugs. On the other hand if your looking for a different sound and looks that's another story but still an expensive program. Modern exhaust systems are very efficient these days and that's why most exhaust companies are reluctant to publish data and those that do are usually bs-ing you.
I also have problems with those intake systems as well. I've seen test results where the power actually dropped. Why? Because most of the systems take air in from under the hood and where the temp can be 140 degrees or more. Ever notice how your stock system gets it air from outside the car? There's a good reason for that. Most dyno results I've seen were taken with the hood open........not closed as in the real world.
Unless you live at the drag strip and every tenth of a second counts. Take the money and spend it on a nice vacation and you'll get more bang for your buck.....
Just food for thought
While it's stupid to get an exhaust system JUST for power, it is a nice plus, unless you think that all reported power gains are just a complete scam (which I find difficult to believe).
I mean, 9-10 rwhp (like in the HKS exhaust) isn't exactly overwhelming, but it's nothing to sneeze at. It's an incremental improvement... and those all add up.
Throw in the improved exhaust note, slightly updated appearance, and slightly lower curb weight, and you have something that at $500-$1000 is at least as good of an investment as, let's say, a $2500-$4000 set of rims IMO...
I would be really suspect of any power claims of 9/10 RWHP for adding just an exhaust......
Not a chance in hell it does that. Remember Tom Cruiser's remark: Show me the money? Well; Show me the dyno chart? From someone legitimate.
There was also this guy, an circus owner I think, who coined the expression: There's a sucker born every minute. Ever hear of it? For me the fish ain't bitting on that lure.....
You will not get significant gains from N/A mods or bolt on performance mods such as an exhaust and intake. You will probably get most hp gain from the LMS exhaust but it will not be legal. I believe that LMS is comming up with a supercharger and that would probably be your best bet if you dont mind your warranty. Good luck!
OK, you're taking it a little too far.
I know it's possible to power a car up a significant amount while keeping it naturally aspirated. There's no single end-all solution, but there are a lot of small changes you can make that can upgrade performance incrementally. I haven't done a significant amt of research into those kinds of mods for the 350 (yet), but I'm sure you can make a decent amount of progress with the car.
Even if there isn't a whole lot available yet, I'd think there should be soon. I knew of people with the IS300 who got that car up to 300+ bhp without forced induction. Legally... (90% sure about that last part, anyways).
