tirerack TPMS question
Old 10-18-06, 03:20 PM
bullit1968
bullit1968's Avatar
Default tirerack TPMS question
I'm getting some Blizzak's (LM-25) and wheels (ASA JH3) along with the TPMS (Pacific 315Mhz + the Fit Kit) through TireRack. I was wondering if any of you have purchased their tire/wheel/tpms packages and if so have you had any issues with thier TPMS setup. Did you have Lexus put the wheels on and register the new TPMS, or did you go through another shop? Any additional recommendations or helpful info would be much appreciated.
Old 10-18-06, 07:31 PM
Pwyll
Pwyll's Avatar
I purchased a second set of Lexus OEM rims, Lexus sensors and pirelli 240 winter sports. Lexus is mounting them all in November.
Apparently, you can only use the Lexus TPSMs to pair with the cars computer.
Old 10-18-06, 09:04 PM
92GreenSC400
92GreenSC400's Avatar
I have the same setup, a set of G-spiders, pirelli snow sports and lexus tpms. I put them on the car saturday and i havent had any problems with the tire sensor going off, so i must have did it right
Old 10-19-06, 12:43 AM
Alex350
Alex350's Avatar
Unfortunately 92Green, your sensor WILL go off pretty soon once you drive for about 20 something miles, you'll see it go off unless you go to Lexus and have them program them (if they're new sensors). If you're using the same TPMS sensors from your OEM wheels, then you don't need to program them at all.
Old 10-19-06, 01:34 AM
bullit1968
bullit1968's Avatar
I guess I should have been more specific - must we use the LEXUS tpms or do the ones that tirerack offer work with the 2IS?
Old 10-19-06, 06:30 AM
mjb2124
mjb2124's Avatar
I'd like to know the answer to this as well. I'm planning on doing the same thing when I get a 350.
Old 10-19-06, 07:00 AM
supaIS350
supaIS350's Avatar
how much is lexus charging to swap out the wheels?
Old 10-19-06, 09:11 AM
IthacaPete
IthacaPete's Avatar
I purchased wheels and tires from Tire Rack. The sensors that they mounted were compatable. I took it in to the Lexus dealership and they had everything set in about 15 minutes. One word of caution, the codes for the TPSM are on a sticker which is placed on the tire. Make sure that you look out for them. Good luck with your new set up.
Old 10-20-06, 05:02 PM
Pwyll
Pwyll's Avatar
I have all the parts separate right now. The rims, the TPSMs (purchased from Sewell Lexus, and the tires.
Have an appointment with my Lexus dealer in November to assemble and put on the car.....$469!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 10-20-06, 05:07 PM
Pwyll
Pwyll's Avatar
IthicaPete....did they swap the TPSMs from your summer tires? If they did, you'll constantly have to keep switching them back and forth, taking off the tires from the rims.
My objective is to now have separate winters (with their own TPSMs) and separate summers.
Now for the next few years, all I have to do is swap in the spring and fall.
CobraGSF
GS F (2016-present)
12-14-16 11:16 AM
SNiiP3R
01-09-15 03:41 AM
NYKnick101
11-18-14 12:07 PM
Aeromotive
Wheels, Tires & Brakes Forum
11-05-14 05:03 AM
ERDoc74
IS F (2008-2014)
12-09-11 04:32 PM
Quick Reply: tirerack TPMS question
