Non Mark Levison nav screen used to play dvd's
Old 11-09-06 | 09:26 AM
  #166
carlos's Avatar
carlos
Originally Posted by omgitsroy
in the mode where you hold say the temp buttom and flicker the light on off on off... you go into that special menu.. there's a thing for DVD there... maybe there's a enable disable function... 800 is a bit too steep for just a module....
how do yo do that?
Old 11-09-06 | 10:21 AM
  #167
tdrag97's Avatar
tdrag97
what happen to the update on the cable from Japan?
Old 11-09-06 | 10:25 AM
  #168
carlos's Avatar
carlos
nothing new yet. im gonna try again this weekend.
Old 11-09-06 | 11:58 AM
  #169
istundra's Avatar
istundra
Try pressing the DISC button TWICE.
Thats how Nav TV is activated.
btw, i ordered Nav TV.
Old 11-09-06 | 12:04 PM
  #170
omgitsroy's Avatar
omgitsroy
you hold one of the big buttons ... i think it actually doesn't matter which... try climate.. then flicker your lights on off on off on off... bout 10 times.... it gets you in that special menu....
kinda like the GPS overide...
also try in reverse cause camera is activated... maybe it's the same line try disc... dunno good luck
Old 11-09-06 | 12:21 PM
  #171
takinover's Avatar
takinover
okay guys I got my hands on that cable from japan also, i will be doing a install this weekend on my car , the cable is not a direct plug and play, i will have to modify the cable so that it work, and if it does, it will allow video to play on the nav and audio using the aux port, I will keep you guys updated on how things goes...
Old 11-09-06 | 12:23 PM
  #172
omgitsroy's Avatar
omgitsroy
weekend again........ yet another weekday tease....
good luck
Old 11-09-06 | 12:34 PM
  #173
carlos's Avatar
carlos
good luck
my weekend starts tomorrow, if that helps
Old 11-09-06 | 12:36 PM
  #174
carlos's Avatar
carlos
mine was a direct plug and play
do you have a link to which one you ordered?
this is mine:
Old 11-09-06 | 02:10 PM
  #175
omgitsroy's Avatar
omgitsroy
yea.......
Old 11-09-06 | 02:12 PM
  #176
omgitsroy's Avatar
omgitsroy
yea.......what i don't understand is that if the module is 800 ... without all the components to play the dvd ...then i doesn't make sense .. unless it's some type of module which regulats what input is being put.. along with a computer... because we all have backup cameras ... that means it's a simple wire input signal... so with the plug that car_lost has.. i don't see how it wouldn't work... the only propllem is enablin the dvd feature..
Old 11-09-06 | 02:18 PM
  #177
carlos's Avatar
carlos
Angry
yea.......
so then what do you have to modify?
Old 11-09-06 | 02:20 PM
  #178
richw350's Avatar
richw350
I am dying to find out what the results are!
Old 11-09-06 | 02:23 PM
  #179
omgitsroy's Avatar
omgitsroy
car_lost .. i just went to my car to check.. there was only a region function for the DVD portion... probably useless
Old 11-09-06 | 02:24 PM
  #180
carlos's Avatar
carlos
you mean for the "secret" nav menu?
