Non Mark Levison nav screen used to play dvd's
Old 11-10-06, 10:51 PM
  #196
2point5is
2point5is's Avatar
oh ok, how do you select the video source? does it run through the reverse feed or something? how much is it, and thats the las question sorry to get off topic.
Landon
Old 11-10-06, 10:58 PM
  #197
istundra
istundra's Avatar
The Kenwood source selector is about $150.00. It has an built in AMP to maintain good feed to the monitor.
It has 3 inputs and 3 outputs.
How does it work?
Each output has their own Wired Remote. Each wired remote can select the Inputs.
Since I am using the Nav Screen as the Monitor, I will only be installing 1 remote.
In the future, I will be installing 2 more remotes and 2 more headrest monitors. Each headrest monitor will have their own remote.
Oh yeah... each remote has their own headphone jack. This is needed for the back seat passengers.
Old 11-10-06, 10:59 PM
  #198
istundra
istundra's Avatar
Landon
Wait... are you asking how do I turn on the source at the OEM Nav? With the module Nav TV, all i have to do is press the DISC button Twice.
Old 11-10-06, 11:28 PM
  #199
2point5is
2point5is's Avatar
oh ok cool thats the way to go it sounds to me.
Landon
Old 11-10-06, 11:49 PM
  #200
viettho
viettho's Avatar
How does it work?
Is this the one you have? http://caraudiosecurity.com/shop/pro...ts_id/125.html
Old 11-11-06, 02:59 AM
  #201
istundra
istundra's Avatar
Yes that's it!
I ordered that Kenwood.
Old 11-11-06, 07:42 AM
  #202
Nicelex13
Nicelex13's Avatar
do we even need the source selector? If someone is just planning on putting the nav tv to just the nav, i would assume we wouldent need that kenwood
Old 11-11-06, 11:02 AM
  #203
johung
johung's Avatar
well the NavTv system only allows one Audio/Video Input..
Old 11-11-06, 11:47 AM
  #204
Nicelex13
Nicelex13's Avatar
so technically if you hooked up a ps2 to the navtv you can get dvds and ps2 gaming w/o the need for the converter..?
Old 11-11-06, 01:57 PM
  #205
istundra
istundra's Avatar
If you want to hook up a ps2 ONLY, then you will not need a input selector.
Old 11-11-06, 02:00 PM
  #206
Nicelex13
Nicelex13's Avatar
as opposed to a ps2 and another external dvd player? I can see the need for one with the headrest tvs though. do you need another input for the actual TV function (to watch cable)
Old 11-11-06, 02:32 PM
  #207
istundra
istundra's Avatar
Nav TV has 1 set of inputs.
If you would like to hook up additional devices, you will need a input selector to connect to the Nav TV input.
Does it all make sense to you?
To watch cable, you will need a cable TV tuner. Not sure where you can buy a mobile cable TV tuner.. but goodluck.
Old 11-13-06, 06:47 AM
  #208
viettho
viettho's Avatar
istundra, how are things going? Got everything set up yet? Another week is just gone by, I (we) can't wait to see the setup. Thanks
Old 11-13-06, 06:52 AM
  #209
carlos
carlos's Avatar
i tried the other things people mentioned and none of them worked
Old 11-13-06, 11:37 AM
  #210
istundra
istundra's Avatar
The parts won't be in until Wed. of Next Week.
I'll have to see then when I will have time to install them.
Quick Reply: Non Mark Levison nav screen used to play dvd's
