Non Mark Levison nav screen used to play dvd's
Old 11-26-06, 01:58 PM
  #271
sepukku
sepukku's Avatar
Originally Posted by istundra
So how about converting the camera's video Input into standard RCA input for external video device?
Have you accomplished that yet?
i have an rca input for the video shown in the first vid..
Old 11-26-06, 06:12 PM
  #272
07Txlex
07Txlex's Avatar
Where ru you located in Texas, maybe after you get all this nailed down I can pay you to take care of mine.. Thanks
Old 11-26-06, 07:39 PM
  #273
sepukku
sepukku's Avatar
Live in plano..
No payment necessary....
But i will be more than happy to help you or show you how.
Old 11-26-06, 08:36 PM
  #274
istundra
istundra's Avatar
The only video that was able to Play is the one that you were driving straight and then turned on the reverse camera.
Can you please convert the video with the RCA input to AVI?
Also, what source did you connect to the RCA input?
Thank you
Old 11-26-06, 09:37 PM
  #275
kensteele
kensteele's Avatar
if you cannot video the video links in the previous posts, i have reposted them in youtube for your convenience:
http://www.youtube.com/watch?v=ZJHm1vNPhS8
http://www.youtube.com/watch?v=KOcDe0IYIqI
http://www.youtube.com/watch?v=xUmrxRqAMKo
Old 11-26-06, 10:20 PM
  #276
omgitsroy
omgitsroy's Avatar
kensteele... is the backup camera constantly on ? or does it activate when you flip the switch? also how did you do that.. cause i'd rather have my backup camera then my navi for the most part... going to work... i know where i'm goin...
Old 11-26-06, 10:52 PM
  #277
istundra
istundra's Avatar
Thank you Ken!
OK i got most of it now.
sepukku, From looking on the em01463.pdf file, i think what you did was locate the Television Camera, cut the CV+ and CV-, connected a RCA wire's (+) & (-), activated the reverse signal (which i do not know how), and your car's HU allowed the new RCA wire's video signal onto the screen.
According to your video, you did this to test. Did you integrate anything permanent for this project?
I know with the use of relays, you can use 1 MAIN Switch to control the input between Television Camera and RCA wire Input.
If what I said is correct about the CV+ and CV- wires, how did you activate the Reverse Camera Input? Care to share?
Old 11-26-06, 11:12 PM
  #278
istundra
istundra's Avatar
ah ha!
I figured it out.
3 relays and 1 switch can ADD a Video Input with the use of the Reverse Camera Input.
Relay 1: Blue JQ1 Wire (12+ trigger to activate reverse camera Input)
Relay 2: Red CV+ Wire (Positive Video Signal)
Relay 3: White/Black CV- Wire (Negative Video Signal)
The switch will control 3 of these relays.
When the relays are at Rest (NO 12V+), all wires will be connected as OEM.
When the relays are at Charge (12V+ Applied), all wires will be interrupted for external connection.
Relay 1: 12V+ to Activate the Reverse Camera Input
Relay 2: New RCA+ (Positive Video Signal)
Relay 3: New RCA- (Negative Video Signal)
So pretty much at a flip of the switch, you would activate the New RCA wire's input.
I think I might be correct. This is untested.
Old 11-27-06, 02:49 AM
  #279
sepukku
sepukku's Avatar
You are correct mostly..istundra.
one minor correction....the cv- is a shielded ground and is not used for the camera signal wire...as that is the first wire that i cut and tapped into.
the two wires that you will have to cut and splice into are the
cv+ which is pin#27 on J51 for the signal.
cgnd which is pin#14 on the J51 connector.
by the way... i didn't use any relays at all...but you can if you want.
i used two switches.
one spdt switch for the activation of the rear camera
and one dpdt for the rca signal wire.
in the configuration that you have described.
Old 11-27-06, 06:00 AM
  #280
carlos
carlos's Avatar
can you play audio from whatever device you have hooked up to play video?
Old 11-27-06, 06:05 AM
  #281
takinover
takinover's Avatar
it seems as though with this modd you will always have the check your surroundings message on the bottom of the screen, or does it go away, from what i have seen it stays there.
Old 11-27-06, 07:38 AM
  #282
|mpulse
|mpulse's Avatar
You will have to pipe it through the Aux.
Stays on.
Old 11-27-06, 09:37 AM
  #283
Nicelex13
Nicelex13's Avatar
can someone start a new thread and post some pictures as you do it? IStundra??
Old 11-27-06, 10:14 AM
  #284
istundra
istundra's Avatar
I see I see... nice work!
With one switch, You should be able to control multiple devices and this mod with the use of relays. Switch being as the master and relays being as the sub switch.
I am still waiting for the Nav TV to be installed into my gf's car but this is a nice break through.
Old 11-27-06, 11:03 AM
  #285
Nicelex13
Nicelex13's Avatar
so by doing this, you can plug the dvd w/o the navtv unit?
Quick Reply: Non Mark Levison nav screen used to play dvd's
