Non Mark Levison nav screen used to play dvd's
Old 12-16-06, 07:56 AM
  #331
07Txlex
07Txlex's Avatar
Damn I wish sepp would report back lol... Anyhow congrats Istundra and I too await your picts and DIY
Old 12-16-06, 10:17 AM
  #332
tdrag97
tdrag97's Avatar
Ok I'm lost now..
The original post with the cable from japan.- DID it ever work? and what happen to that project.
Nav TV is a good company and I know that would work but that is $500+
Old 12-17-06, 01:04 PM
  #333
sepukku
sepukku's Avatar
Alright folks...
i have had my car torn apart for nearly 2 weeks now.
i am unable to make the j52 work without any type of special signal.
there has to be a special signal to trigger the screen to use the j52 input.
this has to do with the avc-lan...hence the reason why the navtv uses the two wires...tx+ and tx-.
it is an emulator of some type.
but i am still working on it so...hopefully i can figure something out without using nav tv.
Old 12-17-06, 04:54 PM
  #334
teejnut
teejnut's Avatar
sepukku- thanks for working on this and sharing your information to all of us! as of now it doesn't look so good to make the j52 connector work so i'll probably use the rear camera method you figured out. thanks for that too!
Old 12-17-06, 05:29 PM
  #335
|mpulse
|mpulse's Avatar
Thanks for all the work and effort sepukku!
Old 12-17-06, 06:06 PM
  #336
istundra
istundra's Avatar
almost done with the install... just gotta do the nav hack right now.
Old 12-17-06, 10:49 PM
  #337
omgitsroy
omgitsroy's Avatar
good luck istundra
Old 12-18-06, 02:25 AM
  #338
istundra
istundra's Avatar
Thanks!
Wow this is by far one of the longest projects I have done.
I have installed the following devices:
Nav TV module
Kenwood Input Selector
A/V Jack in glove compartment to Input 2 (FOR IPOD VIDEO, DIGITAL CAMERA)
Panasonic DVD Changer in trunk to Input 1
I have also done my method of the Nav Hack with switch:
ON POSITION - NAV Hack
OFF POSITION - OEM CONNECTION
I prefer my method of Nav Hack because in the event the car is searching for those wires, a flip of the switch can bring it back to OEM Connections.
I have also wired the Nav Hack Switch to the following:
Nav TV Module
I didn't get to take much pictures becuase I was rushing this project. The IS is going into the Dealer 2morrow for Oil Change and my 3rd Smart Key Programming.
Here are the pictures I have taken:
Switched Nav Hack Relay setup
Nav TV Module
Panasonic DVD Changer Remote EYE
$15.00 Switch from DigiKey
DigiKey Switch Flush MOunted onto a dead panel
And it WORKS! Note this is not a Mark Levinson Navigation
Let me know if you guys have any questions.
Full Speed Ahead!
Old 12-18-06, 03:01 AM
  #339
istundra
istundra's Avatar
Originally Posted by shyishguy
isTundra,
Great job on the install, can't wait for the DIY !!!,
Quick question, Is there any advantages to installing NavTV vs. Hacking the backup camera?
I don't know if I'm missing something - but, The NavTv unit is upwards of $500; while hacking the backup camera is nearly free.
Hm... Disadvantage?
yes there is!
The screen will say "CHECK SURROUNDINGS FOR SAFETY"
AND
The Video Feed will NOT come back ON if you use the climate control, MAP, INFO, Etc.
You can confirm this easily.
Put your car in REVERSE, Press the MAP button.. and then see if you can get back to the REVERSE CAMERA.
I guess you can overcome this by switching the reverse camera switch OFF then ON.
AND YES, I get Both Audio and Video w/ Nav TV.
If any1 in the Bay Area plan to install this, PM ME. I know of a shop in San Jose that will do this install! This is the same shop where I got the part from. They are good friends of mine... I can always step in make sure everything is correct. I already gave them my schematics!
Old 12-18-06, 05:21 AM
  #340
Technique
Technique's Avatar
Great job!!!
PS - Love the family guy screenshots
Old 12-18-06, 07:07 AM
  #341
viettho
viettho's Avatar
istundra,
How is the sound quality of NavTV? I heard that they use FM radio for it? Is that true? Thanks
Old 12-18-06, 10:31 AM
  #342
istundra
istundra's Avatar
It does not use FM Radio. It actually uses the AUX Port.
For OEM, when you press the DISC button twice, the AUX Port will be activated... And for instance if you are in CD MODE, by pressing DISC again, it will bring you to AUX... from AUX MODE to CD, you just press the DISC button and it will bring you back.
To activate the Nav TV is exactly the same thing. Between CD and Nav TV, you simply have to press the DISC Button.
That is why i hooked up the Nav TV to a switch. If you have the Nav TV hooked up to the ACC, you will not be able to use the AUX port inside your arm rest. By having it switched OFF, your car will think everything is OEM. By having it switched ON, your car will think there is a INPUT for AUX and also activate the EMULATION for DVD Changer.
So the sound quality is GREAT. Just how i expected it.
Old 12-18-06, 10:54 AM
  #343
Hartawan
Former Vendor
Hartawan's Avatar
About how much does this all cost?
Old 12-18-06, 11:11 AM
  #344
istundra
istundra's Avatar
Everything?
The module is the most expensive part. I could not disclose the price for the part... but just as shyishguy said "$500+"
The DVD Changer is about $250.00
So assuming you are getting the DVD Changer and the Module itself.. $750? Plus labor and additional parts (wire, connectors, relays, etc)
Old 12-18-06, 06:28 PM
  #345
tqlla3k
tqlla3k's Avatar
Dang.... for $800-$900.... why dont you guys just buy the Mark Levinson head unit? In fact, I think there will be one in the for sale section tommorrow... or maybe tonight!
Quick Reply: Non Mark Levison nav screen used to play dvd's
