View Poll Results: How long do you warm up you engine
None, start it and go!
305
36.40%
About 20 sec., until rpm drops to 1200.
321
38.31%
About 2 min., until rpm drops to 1000.
176
21.00%
However long it takes to get water temp up. (post what temp)
36
4.30%
Voters: 838. You may not vote on this poll
How long do you warm up your engine?
Old 10-22-06, 09:18 AM
jimmyjazz
jimmyjazz's Avatar
Default How long do you warm up your engine?
How long do you warm up your engine before you drive?
Old 10-22-06, 09:34 AM
kensteele
kensteele's Avatar
i wait for 20 seconds because that's about how long it takes me to actually get going, i wouldn't call that an engine warm-up time period. unless you live in mn (et al) you don't need to wait that long (like 2 minutes).
ncatona (12-02-20)
Old 10-22-06, 09:38 AM
Belmont
Belmont's Avatar
I wait about 15 seconds and then take it easy for the first 5 minutes or so until the temp rises.
Old 10-22-06, 10:05 AM
PNice972
PNice972's Avatar
i usually jsut start up and go, maybe like 10 seconds
Old 10-22-06, 10:40 AM
hapaboy
hapaboy's Avatar
until the initial revs drop to that resting point. (250)
Old 10-22-06, 12:37 PM
ToothDoc
11 Second Club
ToothDoc's Avatar
I must be an impatient bastard - I start it and as soon as the engine starts, I'm in R backing out of the garage. I've even put it into R before the engine even started at times!!!
Old 10-22-06, 12:40 PM
tgara
tgara's Avatar
Me too. My warmup is the half second or so that it takes my hand to go from the pushbutton starter to the gear lever.
I thought the manual says not to let the car warm up, just start it and go.
Old 10-22-06, 12:49 PM
kensteele
kensteele's Avatar
i think it's better to wait for a few seconds before you shift the transmission to any gear. unless someone is about to carjack you, i don't see how a couple of seconds will save you any time. better safe than sorry when it comes to the tranny.
Old 10-22-06, 01:57 PM
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 4,042 Likes on 2,448 Posts
The engine warms up better under load. The owner's manual even says, drive the car, don't let it idle to warm up. Idling is one of the worst things you can do to an engine for a lot of reasons. Just drive, but don't beat on it until its been running for about 10 minutes - the coolant may be up to temp, but the oil isn't, and the oil will bypass the filter if it's too thick and rpm is too high (over 3k or so). While it isn't instant death for unfiltered oil to go through the engine, it's not exactly the best thing in the world for a plain bearing engine either.
The gearbox is ready to go in just a few seconds. It has software to prevent damage from doing stupid things. I wouldn't worry about it at all.
Old 10-22-06, 01:58 PM
DonJuan45i
DonJuan45i's Avatar
if im in no hurry ill let it warm up for quite a bit about 5 min, but if I am in a hurry maybe like 1 min and I just really baby the car until it reaches norm. temp.
Old 10-22-06, 02:11 PM
istundra
istundra's Avatar
i turn on.. wait about a minute or so.. make sure everything i am suppose to bring is with me... then i just let the car idle down my block with slight gas... once im at the light... I GO!
Old 10-22-06, 02:59 PM
ABC
ABC's Avatar
I give it usually 30 seconds before i go. But i don't drive it hard until i see the temp guage near the spot where it sits when the car is fully warmed up.
Old 10-22-06, 06:04 PM
PhilipMSPT
Cycle Savant
PhilipMSPT's Avatar
Two minutes.
Why? It takes me that long to get everything ready from seat belts to climate control to radio/XM choices to nav destinations and the such...
Old 10-22-06, 06:41 PM
jman-is350
jman-is350's Avatar
Hahaaha... I do the same. Time is MONEY and cant waste it.
Old 10-22-06, 07:25 PM
ISbb
ISbb's Avatar
if I have the time I will warm the engine up for a min or two but normally I just start up and go since weather in Macao wasn't that cool...Maybe later on when it get cooler I will warm it up a bit longer!!
Quick Reply: How long do you warm up your engine?
