IS350 Throttle Stuck - Near DEATH experience
#76
I'm not tryin' to add more beef to this issue, but I am 70% sure it is driver error, but since it didn't happen to me I really can't say. Also think about it, It is much easier to say "hey u should of done this or done that", and guess what, at that time there is only a handfull who would really think straight in a pannick situation.Just my 2 cent's. I really hope this is just as simple as a floormat issue. At least more people now know to be more alert.
#77
You don't check your rearview specifically for cars with hazard lights on. You simply check your rear view becuase it is good driving practice. If a car happen to have hazards on, you will notice them. If there is a cop, you will notice, if there is a car tailgating, you will notice. Well... most people I know of would notice them anyway.
#79
Ramon I am with you on this, I would notice. I could tell you what is behind me at all times.
#81
Accelleration Problem Does Really Happen
last week my wife was driving her 2006 IS 250 AWD on the interstate (just a day after her 1st oil change at the Lexus dealer). While having the cruise on 65 degrees, she decided to pass a semi. She advised that she just touched on the gas pedal, and the car accellerated right up to 90mph instantly. The RPMs went all the way up to the end of the red line. She stated that she tried to put the car in neutral, but that didn't help. She tried to slow the car with the brakes, but that too was a struggle. The gas pedal wasn't to the floor she stated to me. She was able to drive into the grassy median and slam on the brake. The engine was still reving at full speed, so she "Slammed" it into park and turned off the engine. Ouch! Lexus sent out a tow, and at the Dealer, the tech started it and it was fine. When he gave it gas to test drive it, it floored again. He ended up pushing it into the stall. He could not find anything wrong with the engine, so he called Lexus Headquarters. They suggested to check the all weather mats. The tech stated to us that the mat looked fine when he looked at it, but when he tried to pull it out of the car, it was stuck to the gas peldal. Apparently Lexus knows of this problem. The dealer guess that when the dealer changed the oil, the kid who did the car wash and pulled out the floor mat to clean it must not of put the mat back in correctly. Lexus must know of this problem and they better fix the problem before someone gets killed. So far no probems with the Engine or Transmission.
#84
you will destroy your brakes (they will fail / explode given enough heat; this situation will cause enough heat for the former and could possibly lead to the latter). use them as the final measure in bringing the car to a stop. Shift to neutral, I do not see why this would not work. Kill ignition if needed, then brake. I have been through this before in my old GS a couple times and for different reasons (floormat being one).
#86
I agree with NoRyce. There is absolutely no reason why shifting to neutral would not stop the car from accelerating. I think people feel that neutral should slow the car down immediately, but obviously it won't do that.
Note to self... don't get all season floor mats...
Another note to self... you live in Texas and dont need them!
#87
OK the throttle getting stuck - I believe is very plausible... probably from your floormat whether or not you realized it. But in the rare case that a car with electronic throttle control actually had some sort of ridiculous software glitch that caused the computer to just floor the car despite no physical pressure on the throttle... I mean I guess I could see that being possible.
But the car not shifting into neutral when you put it into neutral?? That's a direct/physical connection there. No 'transmission select by wire' like 'drive by wire'. There's no throttle or 'bug' that would cause it not to go into neutral.
Granted I suppose your transmission selector could fail at the same time as your electronic throttle control but I think you have a better chance of being run over by a pink 747 while battling a radioactive 2 ton rat on the moon.
#89
there's no reason why not to purchase all-season floor mats. i've used them for many years in a couple of cars, no problems. it snows in texas, it rains, there's ice and inclement weather, and it's filthy so all-season will go a long way protecting texan's cars, the benefits far outweight the occasional (potential) runaway car.
#90
