Clunk sound when shift from P/N to D
Old 11-03-06, 07:38 PM
okiaristo
okiaristo's Avatar
Universal joint/pinion gear slack.
Old 11-03-06, 10:11 PM
Ramon
Ramon's Avatar
Originally Posted by kensteele
waiting for a tsb first before i ask them to go monkeying with it.
Don't hold your breath for that tsb... My service tech tells me that the pad shifting noise has plagued them since the 1IS. All they can do is grease it up, but eventually, the sound will come back.
Old 11-03-06, 10:36 PM
Dj_AmtraX
Dj_AmtraX's Avatar
SAVE your transmission! Use your Parking Brake to hold the car! Brakes are design to stop/hold the car.
The clunk I hear is from N to D in the morning.
Old 11-04-06, 08:35 AM
kensteele
kensteele's Avatar
are you saying that because you've had a transmission go out on you because you didn't parking brake it first or maybe you know somebody who's transmission broke because they used it to keep their car parked....lol.
sorry, just trying to figure out if it's a dumb ritual or are there any facts.
btw, it's called putting your car in Park and using the emergency hand brake...seems to me when you park your car, you use it that way.
Old 01-09-11, 09:58 PM
panda327
panda327's Avatar
i have this problem ... even on a warmed up start and on a flat surface... its really annoying and its really loud .. and the car is only 2 years old with 33k km on it ... is there no temp fix?
its usually when i let go of the brakes
Old 01-09-11, 11:12 PM
ChickenIS
ChickenIS's Avatar
No clunk at 60k miles.
Standard parking procedure:
1. Stop car in D
2. Hold brake pedal
3. Shift to P
4. Press parking brake
5. Release brake pedal
5. Kill engine
6. Exit.
Old 01-09-11, 11:24 PM
panda327
panda327's Avatar
1. Stop car in D
2. Hold brake pedal
3. Shift to P
5. Kill engine
6. Exit.
i do this religiously and i still get the sound
Old 01-10-11, 03:07 PM
ChickenIS
ChickenIS's Avatar
Sorry to hear, good luck
Old 01-10-11, 04:47 PM
jbjones85
jbjones85's Avatar
My process park, shift to neutral, apply parking break, shift to park, release brake, turn off. No clunk that I have noticed.
Old 06-03-22, 02:07 PM
Tmmramos
2nd gear
Tmmramos's Avatar
Default Same issue. Any help?
Hi guys. Tiago here from portugal.
I’ve a Lexus is250 and a couple of days it makes this sound when cold coming from de bottom of the car and vibrating under the shift console. It’s loud from inside the car. Here’s the video.
any idea?
File Type: mov
TrevorR
GS F (2016-present)
08-08-18 11:40 AM
05Flagship
08-08-15 10:03 AM
ladyrocket
ES - 6th Gen (2013-2018)
02-16-13 01:40 PM
nighthawk
Suspension and Brakes
07-31-11 04:13 PM
maz
02-06-07 04:37 PM
Quick Reply: Clunk sound when shift from P/N to D
