View Poll Results: Hardwired or not
Hardwired
43
56.58%
Cigarette lighter
33
43.42%
Voters: 76. You may not vote on this poll
Valentine 1 poll
Old 11-02-06, 02:17 PM
murph550
murph550's Avatar
Default Valentine 1 poll
For those of you with a valentine one, are u using it through your ciggarette lighter or have it hardwired? Also post where on ur windshield u mounted it; and if its hardwired what powersource u tapped into ( ex. sunroof, mirror, fusebox).
Old 11-02-06, 02:22 PM
07Txlex
07Txlex's Avatar
I know this question may start a controversy and kinda jack your thread. But is the valentine better or about the same as the Escort 8500 in primarily city driving?
Old 11-02-06, 02:25 PM
istundra
istundra's Avatar
i would tap it to the cig lighter. definately not in the fuse.
Old 11-02-06, 02:50 PM
is4me2
is4me2's Avatar
Cool
Hardwired through rearview mirror:
Old 11-02-06, 03:10 PM
VikH
VikH's Avatar
Cigarette. As I use it in other cars and would not like to F with hardwiring. It is located in the center of the windshield, about 4 inches bellow the mirror. Have no problems and allows me to remove the detector to store quickly when I park.
Old 11-02-06, 03:11 PM
jcreech
jcreech's Avatar
Hardwired to fuse box, took me 20 minutes.
Old 11-02-06, 03:31 PM
TXIS350
TXIS350's Avatar
Default V1 INstall
Mounted just below rear view. Run wire up the channel for the rear view to head liner then along right side down to fuse box under Glove compartment tied into fusebox. Cig lighter fuse. very easy install. Wiring totally out of sight.
Old 11-02-06, 03:40 PM
istundra
istundra's Avatar
I URGE YOU NOT TO DO THIS! THIS IS UNSAFE! HOW ARE YOU GOING TO SECURE THE WIRE?
Please do not do this. It is not safe at all.
Old 11-02-06, 03:41 PM
istundra
istundra's Avatar
X2!!!!
Old 11-02-06, 05:05 PM
isgrrl
isgrrl's Avatar
not to sound like an idiot, but what's so bad about connecting it to the fusebox?
Old 11-02-06, 05:31 PM
Poman
Poman's Avatar
Just remove the rear view mirror and tap in the wires, nice and clean. Someone here has the DYI with pics!
Old 11-02-06, 05:34 PM
murph550
murph550's Avatar
i think it has to do with the fact that you can't really secure the wires completely. I may be wrong though.
Old 11-02-06, 06:58 PM
istundra
istundra's Avatar
1. You cannot secure it properly.
2. You are putting your car's electrical system at risk.
3. Increase chance of shortage.
Just run a (+) line from your CIG Lighter. It is the ORANGE color wire. Use T Taps and get the 12V there.
If you were to bring your car to any qualified technician, they would call a fuse box tap a mickey mouse job.
Old 11-02-06, 06:59 PM
istundra
istundra's Avatar
Tap the Rear View Mirror Lead? Is it Switched or Constant?
If it is switched, I would say YES.
If it is constant, then your device will be on ALL THE TIME.
So please... Tap a switched (+) signal properly... Do not use those Fuse Box Tap ghetto rigged half *** job technique.
Old 11-02-06, 07:18 PM
6MTIS250
6MTIS250's Avatar
dont ever mess with your car electronic stuff, if you dont know what you are doing, cuz if you do it wrong might lead to fried ECU or others
little wire can cost alot of problem
Quick Reply: Valentine 1 poll
