Xenon Depot HID IS250 install pointers
Thanks to all the help on this site I installed my Xenon Depot kit today. A couple words of warning. I read on here install in about an hour. Give yourself much more time to install, and I am pretty handy. Also if you have large hands get some smaller ones for the driver side. There is a posting on here that talks about putting in 2 holes on the dust covers for the wiring. If you take the adapter off for the stock harness you can put the two wires through the large grommet, there are two small holes there you just need to open them up a bit with a small drill bit. Peel back the casing a couple inches that surrounds the two wires to give yourself some play. Also make sure you plug in your mass air sensor before you try the lights out or you can get an error message. Good luck!
rdrunner
09-20-15 11:10 PM
