10,000 mile service....?
so I called lexus and they told me that it ws going to be $180 for the service.... which is only oil change, air filter, and retorque...
I called toyota and they told me it was going to be between $60 and $80 to do the scheduled service....
You think its ok to go to Toyota? I mean... its not a major service or anything..... thoughts?
I wouldn't go to the Toyota dealer. Besides not having the parts and not having much experience with Lexus cars, if they found something that could be fixed under warranty they couldn't do it there. You would have to go back to a Lexus dealer anyway.
This is VERY simple.
Make an appointment to get JUST an oil change. Buy the air filter yourself and change it!
Its so simple. I dont know why people pay this much just for regular oil changes.
Shoot. Come over my shop and I would be happy to do this for $180. I have a shop in Anahiem, CA. I wont even charge you tax!
The re-torque may be referring to the propeller (drive) shaft.
If you have no vibration, and no one has removed the bolts at the U-joints, they have green Loctite applied and should not be a concern.
The torque values I would be concerned with is the 76 Ft Lbs. at the wheel lugs.
did my 10000k last september and asked for just the oil change ...a whopping $53
i waited about an hour and was outta there. i guess as the miles goes up and as i need more service then the cost will rise but for now maintence and costs have been under the control
The Denso part number is usually molded onto the engine air filter edge. This makes a Toyota dealer replacement a little less expensive than the Lexus replacement.
Along with the engine air filter, the cabin air filter may also require a quick inspection and vacuuming.
I live off on Euclid and almost hitting 10K and Im thinking of taking it
to the toyota dealership off euclid and 91fwy.
CAn you tell me where I can buy the air filter?
Thanks in advance,
Vjanakir
09-09-17 04:38 AM
MrEandJ
ES - 6th Gen (2013-2018)
11-24-15 05:09 AM
baxter0755
04-10-10 06:34 AM
