Fake grill by fog lights
It surprises me someone hasn't cut that out and made a real grill and duct cool air either to the brakes or to the bottom of air box. Thoughts?
Aloha,
Larry
Aloha,
Larry
Are the small grills by the fog lights fake? I think so but haven't removed the under hood covers to inspect. If so it would be easy to remove the fake cover, cut a hole, make a real grill and cut a couple of holes in air box and run ducts to it. The more cool outside air the better. Someone care to inspect and try it???
Aloha,
Larry
Aloha,
Larry
Tech Info Resource
Despite popular culture and magazines, the coolest air isn't anywhere near the ground. Take some measurements for yourself on a hot day over black asphalt. The coolest air is nowhere near the pavement. Pulling in air less than a foot off the pavement only works in places where the roads are not black and the ambient temperature is so cool it wouldn't matter anyway.
Having spent a considerable amount of time working on aircraft parked on both concrete and asphalt, it's painfully obvious to me that the air at 3 feet off the surface is a lot cooler than the air at 6 - 12" is. If you look at motorsports where small differences in power make big differences in results, you always see the engine air intakes well above ground level. It's not for fashion.
Aloha,
Larry
This is usually because the area 6-12" above ground is reserved for more important items, like wings, underbody venturis, etc. Ground effect aero can contribute (in cases of F1 and the likes) up to 70% of the total downforce on a racecar. But your point is valid too . Its also impressive to see how small the openings are, especially in F1, where the size of the air intake is actually unrestricted. You get some serious ram air effects at 180+mph....
Angel350
05-24-08 11:34 PM
