Spoiler Installation
Old 11-15-06, 07:43 AM
Technique
Technique's Avatar
Originally Posted by kenjimaru
First of all, to clean the entire trunk area well is really important by stripping all the wax off the surface. I've had a little bit of problem letting the template stick to the trunk surface for proper drill-hole positioning.
Other steps of the installation process are pretty much standard. We sprayed some windex on the adhesive tapes that comes with the spoiler and let it kinda "glide" on the trunk surface for proper positioning purpose. After the position is secured and the three screws are bolted on, a heat gun is used to ensure both end as well as the rest of the of the spoiler properly stick to the trunk surface.
Hope this helps with your installation.
Why do you need adhesive tape in addition to the screws? Will the ends of the spoiler not lay flush without tape?
Old 11-15-06, 07:49 AM
kenjimaru
kenjimaru's Avatar
Tape that came originally with the spoiler, not in addition to the screws.
Without the tape attaching the spoiler to the surface, two end will certainly slightly stick up instead.
Old 11-15-06, 07:52 AM
Technique
Technique's Avatar
Hmmm, that's disappointing for an OEM spoiler... Oh well, whatever...
Old 11-15-06, 08:17 AM
kenjimaru
kenjimaru's Avatar
ah dang
Old 11-15-06, 09:13 AM
combfilter
combfilter's Avatar
Here's how I did mine. First I dremeled off the screws. However, this was kind of the cool part. I didn't have a great bit so I was just using force with a crappy bit. Well after about 2min, on one screw the base holding the screw got so hot that you could pull the whole screw out like butter. Then I filed down any edges where the screw was previously at. Then i put the red 3m tape that you get at an auto store inside the spaces that the stock tape didn't cover. Then just stuck it on. Didn't have to use any screws or drill.
looks good too.
Old 11-15-06, 10:30 AM
johung
johung's Avatar
that's a lot of work... but i'd rather not get it drilled either. thanks for the info!
Old 11-15-06, 10:43 AM
kenjimaru
kenjimaru's Avatar
yeah i didn't want to have it drilled either, hehe, but i guess drilling gives you a peace of mind.
Old 11-15-06, 08:03 PM
kenjimaru
kenjimaru's Avatar
sorry to bring this up, but if you would like to call Harrison before 12:00 pm every day will be effortless, just a little reminder from people who had sent me pm in regards to this!
Old 11-16-06, 03:36 PM
kenjimaru
kenjimaru's Avatar
just updated his cell phone number in the thread, changed as of today, i know a lot of people are interested in having shocks/spoilers/GFS kit to be installed for a discounted price, and his excellent service can come in handy for people on limited budget.
oneor11
ES - 6th Gen (2013-2018)
49
12-19-16 05:01 AM
Stevent
10-12-15 08:10 PM
doctorttt
07-06-06 06:00 PM
rx300force
10-16-05 02:26 AM
vinster29
RX - 1st Gen (1999-2003)
04-29-04 11:53 PM
Quick Reply: Spoiler Installation
