Another Winter Tire Question - Same Size ???
Used the search but can't find what I am looking for. My question is:
Can I run 225/40/18 all around for snow tires on an IS350 ?? Will they fit OK???
I want to use the standard rims (18 inch) for snow tires and get a new set of rims in the spring. Any help appreciated, thanks.
You can but the sidewall in the back will be stetched a little. Here in UT I had the same ?'s I found that there are companies (Cooper Tires I think) that make winter tires in 245/45/18 but they get expensive. 225 up front and 245 in back cost around $1000. I'm going to look at all-seasons they should be less and still be drivable. But that's just me.
Why not get snow tires with OEM sizes? I understand the desire to maximize winter traction by increasing sidewall height and running a narrower width, but will the difference in overall traction overall be significant? I see you live in Canada, but did you look at winter tires in OEM size? I live in Michigan and with the one run in with snow so far this year, my Dunlop WinterSport M3's did well with 255's in the rear and 225 up front.
