will this offset work?
11-27-06, 12:50 PM
will this offset work on a IS250? thanks in advance
19x10 with a +30mm , currently i have 19x9.5 with a 38mm..........
11-27-06, 01:38 PM
are you talking about the front, rears, or both?
Regardless, I don't think they'll work anywhere as that offset is too low.
11-27-06, 01:40 PM
rears, it pushes it out and additional 14mm or so, yeah it would be pushing it.............i really dont want to role my fenders.
11-27-06, 02:05 PM
Quote:
Originally Posted by
kilo6_one
19x10 with 30 offset will not fit even if you roll the fender. 19x9.5 with the 38offset will fit perfectly in the back.
11-27-06, 02:36 PM
Hutch27
Yup. I've got 9.5" with +40's in the rear and I can't see going much more than that as it is perfectly flush.
11-28-06, 11:28 AM
al503
What do you have in the front and do they rub?
11-28-06, 11:35 AM
IS350FL
I've got 8.5" +40 and they're very close to flush also. Once you start to get into the +30's, the wheel will start to go past flush.
11-28-06, 12:07 PM
Thank you that is the size I want. Does the front rub?
Are yours 19's?
11-28-06, 12:35 PM
IS350FL
Are yours 19's?
They're 18"s with 235/40/18 tires, which are very slightly oversized. I had a very minor rub with the fender liner in the back of the fender well (not the fender itself) but that was taken care of very easily with a heat gun.
ex00
09-17-18 09:25 PM
IS_NIICE
05-24-07 07:57 PM
2jzz30
Wheels, Tires & Brakes Forum
02-12-07 08:53 AM
kilo6_one
11-28-06 06:55 PM
Switch
01-23-06 05:43 PM
