Excessive Wind Noise with Sunroof Closed
Driving up to Hearst Castle over the weekend at about 70mph. Sunroof was closed but I noticed a ton of wind noise, almost sounded like something wasn't sealed properly. Never gotten any water in despite a couple rainstorms and washing the car many a time.
I usually drive with the sunroof shade closed so never noticed this before.
Anyone else run into this?
I had the exact same problem, turns out the sunroof glass was warped slightly. Once they replaced that, no more wind noise at high speeds. Took them 2 days to figure that out, but they got it right.
I had the same issue as brel523, warped moonroof glass... do a search on wind noise and you should be able to find my thread about the hell I went through to get it fixed.
BTW, replacing the glass did the trick. Whisper quite now.
Thanks all. Good to know. I also have a fair amount of wind noise on the driver side window frame but none on the front passenger side. I wonder if this is the same issue or related to the annoying ticking by my left ear.
i have wind noise issues too but the thing is...i don't particularly hear it coming from the sunroof... i mean i was going 20 mph and still heard it... which i'm a little dissapointed... sitting in my brother's new GS and my IS comparing the differences between the two... there's a big difference...the gs is silent... the is... is fairly quiet but i just think i'm picky and i want it to be silent.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Overall this car is TONS noiser on the hwy than my ES? It's not a huge deal, but that's one thing I did like about the ES, whisper quiet on the hwy. I realize this has much lower profile wheels and a firmer suspension, but the excessive howling etc, is a bummer!
No noise when it's closed, but oh my G is there a lot of wind noise when it is all the way open at 70mph. Louder then my last car by far. Last car I used to forget it was open, not in my IS.
![DJ](https://www.clublexus.com/forums/images/smilies/DJsmile.gif)
Did you ever get this figured out? I have your problem but it's coming from my passenger side ![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Overall this car is TONS noiser on the hwy than my ES? It's not a huge deal, but that's one thing I did like about the ES, whisper quiet on the hwy. I realize this has much lower profile wheels and a firmer suspension, but the excessive howling etc, is a bummer!![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Tech Info Resource
Mine is quite a bit noisier with the shade open. Those who have got theirs fixed by replacing the glass - is it equally quiet with the shade open or closed? If so, I'm going to have my glass replaced...
Tech Info Resource
There is no TSB for this.
