Navigation Hack Alternative - Hybrid Nav DVD
Old 09-07-07, 05:35 PM
  #166
Technique
Technique's Avatar
Originally Posted by omgitsroy
can some software genius jus go into the dvd and jus replace a file ?
No... It's not like the Acura nav unfortunately
Old 09-09-07, 07:34 PM
  #167
i3urton
i3urton's Avatar
how do i remove the dvd disc behind the hazard light?
Old 09-13-07, 11:43 PM
  #168
Joe Z
Joe Z's Avatar
Received 1,063 Likes on 586 Posts
Confirmed New Map DVD Data: ver .07.1
I guess I'll be the 1st to tell you all that the 2008 IS's with Nav come w/ the new software...
SO, before I do any hacking.. is there anything I should do and/or try first???
Joe Z
Old 09-26-07, 08:27 PM
  #169
nhawk2
nhawk2's Avatar
Yes, 7.1 introduces a short "don't look at me while driving screen" which automatically disappears after 5secs, but also doesn't allow you to get past it in less than 5secs.
If upgrading an older DVD, it updates the firmware and disables the override present in most/all 2006 IS. However, a hybrid disc with 1600 firmware can be made to allow both 7.1 map data and override (allows entering nav dest. while driving)
Not sure if Technique already stated it somewhere else, but when burning a hybrid disc, make sure you do it as ISO9660/UDF (not full UDF). Nero doesn't support ISO9660/UDF with >2GB files, so use Prassi or GoldenHawk software which allows 4GB files.
Old 09-26-07, 09:10 PM
  #170
ES3
ES3's Avatar
Now THAT would be a sweet hybrid disc!!!!
Old 09-26-07, 09:40 PM
  #171
lobuxracer
Tech Info Resource
lobuxracer's Avatar
Received 3,991 Likes on 2,415 Posts
Imgburn works very well for this too.
Old 09-27-07, 07:53 AM
  #172
ben_r_
ben_r_'s Avatar
Man i wish I had an '08 disc to try this! Why do those stupid things have to be so expensive!? I mean come on they already got us on the car! Cant they just hook us up on the nav discs???!
Old 09-27-07, 03:22 PM
  #173
Joe Z
Joe Z's Avatar
As seen on TV:
My Screen has been Protected by AeroTect!!!
Old 09-27-07, 05:13 PM
  #174
Pnuge88
Pnuge88's Avatar
why is this all soo complicated.. stupid lexus.. i just wanna snip the wires and be over with this stupid safety feature lol
Old 09-29-07, 12:43 AM
  #175
i3urton
i3urton's Avatar
i have the iso nav hybrid iso burned on my comp but i cant seem to be able to burn it onto a dl disc with my hp 740b dvd burner...which supports dl dvds....i used memorex and Nextec dvd discs..
Old 09-29-07, 01:48 AM
  #176
thelads
thelads's Avatar
Originally Posted by cobestr
I had a weird one happen when updating my 05 lexus rx330. I was going from 4.x to the 6.x maps with the 5.x over ride. new maps loaded and I still had the over ride. The problem was I could not select a region. It was just blank and the change button did nothing. This in turn disabled address input and any poi info, since it did not know what region to search. Although it would still navigate to memory points.
Same Here except I didnt use the 5.x and now I've lost my override - were you able to fix?
Putting my 4.1 back in restored everything back to original except for the override is now gone. If I could just "reset" the nav and go back to my 4.1!
Old 09-29-07, 07:46 AM
  #177
wakaru8
wakaru8's Avatar
Glad to report here that I got overide to work on my 07'. I had a u30/5.1 disc originally and the nav firmware was 1650. Replaced the loading.kwi with one that is of the same region 'u30'. Used imgburn to create the .iso and Nero 7 to burn the dl disc. O, and I used a Verbatim +R DL disc and NEC-3520A burner. For those that are having trouble burning the hybrid disc, first make sure your burner is running firmware that supports bitsetting booktype.
Old 09-29-07, 12:59 PM
  #178
revitupwio
revitupwio's Avatar
^ could the dummies get English, please? or wouldn't it do any good?
Old 10-29-07, 12:51 PM
  #179
sf7307
sf7307's Avatar
I'm trying to get a handle on this. Please confirm:
1. The "hard" version (cutting wires; installing switch) allows NAV input while driving, caller ID, phone number input while driving, dvd watching, BUT can cause nav issues (I don't understand why you would do this if it will cause NAV issues)?
2. The "soft" version (hybrid disk between 5.1 and 6.1) only gives you the ability to input a new NAV destination, but doe not give you caller id, phone number input or dvd watching.
Am I correct?
Old 10-29-07, 01:21 PM
  #180
Technique
Technique's Avatar
Am I correct?
Everything you wrote is correct except there are no "nav issues" with either one. In both cases, everything works flawlessly if you do the hacks correctly.
Quick Reply: Navigation Hack Alternative - Hybrid Nav DVD
