Navigation Hack Alternative - Hybrid Nav DVD
#227
Currently we have two Garmin 2730 street Pilots for each of our two cars. We are ready to replace our RX330 next month. A must have accessory for any vehicle we get is a factory navigation system because I want to have the much larger and much more useful map display. We certainly prefer another Lexus RX series because we have like our RX330 so much. However, this is rapidly falling off our short list solely because the navigation system is not fully functional when the vehicle is underway.
I am debating whether to just use the new disc because the firmware might improve the speed of the system.
#229
If my Lexus can tell when the passenger side airbags should be on, Why Can they not program the Nav to work while driving if a passenger is in the car.
If it worked when a passenger was in the passenger seat then they could use the Nav system.
#231
What does the screen say? If you are getting the japanese letters, just press upper left, lower left, upper left, lower left and it should eject...
#232
Nav DVD
All I have a black screen with white lines going down it. I also called Lexus they told me the computer needs to be programmed and i've to bring it in (btw they charge $100 for the programming). does anyone about this?
#233
Don't take it to the dealer... Keep pressing the corners of the nav screen and the disc should come out... try different conbimations, like upper right, lower right, upper right, lower right... Or upper left, lower left, upper left, lower left... Let us know what happens...
#234
Technique,
So grateful for your help with my 2007 IS250 about two years ago. I am back with a '09 ES350 with the 8.1 Nav. Has anyone confirmed the question of whether the V1550 firmware will work with the V8.1 DVD Nav data?
#236
Can someone post the vital stats of the 8.1 DVD to this thread, please? I haven't seen the disc yet and I'd like to see a directory listing with file sizes and part numbers for the DVD if someone could take the time.
Thanks!
SonarTech
Thanks!
SonarTech
#238
The directory is labeled with "464210-1160"
#239
No dice!
Ok I took my loading.kwi file from my old 5.1 disc, combined it with my 8.1 data. I get a "cannot read program" error. This after unplugging battery.
Mind you this is the same procedure I followed back when I made a hybrid disc with my 7.1 for my '06 IS.
Anyone have any suggestions on what to do?
There has to be more to it than the loading.kwi, just by looking at the file sizes, 5.1=46meg 8.1=116meg!
#240
I'd suggest trying a few more times, and maybe burning a new copy, double check your book-type, etc...
