D4S Replacement bulb questions. Melted wiring? OH NO!
So, I bought the 6000K D4S replacement bulb from Xenonvalot and the bulbs just came in today. I went to my local dealership to ask them to take the OEM bulbs out for me so I can put on my new 6000Ks and one of the technicians said that the replacement bulb will melt my current HID wiring; and if that happens it won't be covered under warranty . He even said he's seen it a couple of times when people tried this mod and their wires just completely melted.
My questions are, How is a bulb with the same wattage going to melt my wiring(is it because it burns a lot hotter than the OEM 4300Ks?)? Also, do any of you who already did this mod have lighting problems? (i.e. melted wiring or any other type of problems...if you don't know you might want to check the wiring ) Thanks in advance.
Hope everything turns out well.
-Justin
-Justin
it shouldn't melt the wiring. from what i know, they're supposed to be pulling the same wattage. no problems for me yet, its been only a month though. my friend who works at lexus and the parts manager both told me that the oem harnesses are very strong to begin with.
-Justin
-Justin
Yeah, that's exactly what I thought...same wattage no harm, right? Also, I didn't want to doubt Lexus making a weak harness for our HIDs. I didn't know what the tech was talking about =/....maybe just to scare me just in case I ****ed up while installing? Thanks Jsquared and Alex for your fast response.
I notice something with the stock HID that I wonder if by changing to the 6000K xenonvalet bulbs will it be gone. When I get close enough to the car in front of me the top of the light on the bumper looks a bit yellow. I thought it may be the driving light, or whatever that is called, but now I'm thinking it may be the 4100k or 4300k stock hid that is putting out that yellow. I see the same yellowish when I park in front of my garage. I see a tinge of blue at the sides of the light but yellow on top. Hopefully you know what I'm talking about so you can answer my question.
Thanks
Hi JS,
Thanks
Thanks
i'm guessing it is the parking light. the stock hid's should be pretty much white with maybe a very slight blue tint. the parking lights are just plain 194 bulbs, the same as the puddle lamps, vanity lights, and interior front dome light. you can see that those are just the plain white-yellow color. the way the lights are positioned, the parking lights are placed slightly higher the hids.
I'm actually changing out the parking/driving light, along with the high beam/drl once I get my car in to have the fogs changed to HID. I was planning on going 4300K fogs to match the stock HID but then this yellow thing got me thinking I should go for the more expensive 6000K fogs and spend some money on upgrading the stock HID to 6000k. I can save like $600
by not going to 6000K all around.
haha too late for me... but yeah, it should look good with everything matching. post pics after! how much are you spending on the fogs? the 6000k fogs shouldn't be priced more than the 4300k fogs. if anything, maybe $20.
XenonDepot is having a GB right now for hid kits, the parking light leds should be like $10 and it seems that you can get the bulb replacement for anywhere between $150-250 depending on where. so based on this, from stock to 6000k, you could replace the whole front lighting for $600-700.
