07+ Nav. Service Menu
Lexus Connoisseur
As found on the LS forums. Use at your own risk:
https://www.clublexus.com/forums/sho...d.php?t=251161
Just figured this out. Access the Screen's technician controls, service schedule, bluetooth, etc. by the trick below. I'm in Taiwan so this might not work with all the US models.
1) Without pressing on the brake pedal, push the engine start button so the engine does not start but ignition is on.
2) Hold on to the "DISP" switch on the left side of the screen and switch your headlights from the "off" position and "parking light" position. Keep repeating this procdure while holding on to the "DISP" switch and screen will turn into "TECHNICIAN" mode.
Hopefully this can help people tune part of their screen's access menu. But if you don't know what you're doing, please don't mess around with this.
