Door panel removal (pictures)
Old 11-30-06, 10:06 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Default Door panel removal (pictures)
Tools:
screw driver (flat & philips)
Panel poper
Then pull at all corners.
Old 11-30-06, 10:22 PM
javyLSU
2IS OG
javyLSU's Avatar
Awesome post! I know a lot of us have been wanting a guide on how to remove the door panel. Great pics, too!
Javier
Old 11-30-06, 10:30 PM
shrka
shrka's Avatar
you are brave...thanks for the diy
Old 12-01-06, 05:02 AM
G35TOIS350
G35TOIS350's Avatar
dont see any pics
Old 12-01-06, 06:45 AM
carlos
carlos's Avatar
i've posted pics before.
Old 12-01-06, 06:49 AM
carlos
carlos's Avatar
https://www.clublexus.com/forums/sho...d.php?t=238058
Old 12-01-06, 06:55 AM
carlos
carlos's Avatar
i also edited that post up there to reflect my new findings
Old 04-21-07, 05:58 PM
Dj_AmtraX
Dj_AmtraX's Avatar
Don't forget to disconnect the two cables.
Old 04-21-07, 06:33 PM
istundra
istundra's Avatar
wth. wut areyou installing? Also, there is a trick to re-install the door panel.
let me know if you don't know
Old 04-22-07, 05:05 AM
A.C Milan
A.C Milan's Avatar
thanx for the pics .. hope i dont get forced by future rattles to to do this.
Old 04-22-07, 08:01 AM
kattanh3
kattanh3's Avatar
useful post, thanks Dj... I needed this DYI guide to install sound insulator sheets
Old 04-22-07, 10:02 AM
nabisco
nabisco's Avatar
Great info. Thanks!
Old 04-22-07, 10:57 AM
ULTiMaX99
ULTiMaX99's Avatar
i'm sure this will be very useful! thanks for the pics! just be very careful with the switches... i've been told they're fragile and are pretty expensive to replace.
Old 04-23-07, 12:44 AM
Dj_AmtraX
Dj_AmtraX's Avatar
The switches can be removed from the plates. That means for those who wants aluminum, you can buy it at the dealer without the switches.
Old 04-23-07, 06:06 PM
ahohnstein
ahohnstein's Avatar
Dj- thanks for the pics. I have a question. I have some replacement sills that I need to install (my tinter nicked them all up so I had to get replacements). I've gotten to the point of trying to pull the door panel off. I'm a bit scared to yank it because it feels like the fiberboard panel is going to break before the fasteners give. When you removed it did you give it a good pull/yank or did you slowly pull until the fastener popped loose? I'm just afraid to ruin the door panel.
Quick Reply: Door panel removal (pictures)
