ISX50 Alarm sufficient to protect the car?
I've added an aftermarket glass sensor for $90 installed. It will not stop any motivated thief from stealing the car. But at least the alarm will go off once the glass is broken. I'd rather have the alarm going off while they are doing their thing rather than total silence. Consider it a deterent. Yes the damage would already be done, but at least they might think twice about going further if the alarm is going off. Plus, $90 is not expensive at all.
I found it.
http://cgi.ebay.com/Automate-415-Car...em260057845752
It is actually Automate model # 415.
Very cheap price on ebay. whoever who wins the bid, please share your experiences.
I found it.
The majority of factory alarms out there are not sufficient enough to protect your car from getting stolen. You have to go aftermarket. That's questionable too. When you're dealing with a low class thief......if they can't steal your car, they may damage it in other ways out of frustration. So you at least get to keep your car, but you have to lose it for a week or so while it's getting fixed.
I wouldn't waste the cash on a shock sensor. By the time they break your window and the alarm goes off, it will take all of 2 seconds to reach in and grab whatever they're after. The key is to keep valuables out of obvious view...this is why I don't have a radar detector, any aftermarket electronics, etc. in the car. Most thieves are going to go for the easiest target.
Shock sensors don't always detect glass breakage anyway, which is why glass breakage sensors are used. IMO, the purpose for these sensors is to CATCH the theives, or scare the hell out of them so they won't do it again. I fear that the theives that broke into my car will try it again since my alarm didn't make a peep the first time.
How did you come to this opinion? I'm a techie from way back, and have been developing automotive computer hardware and software for years (see last link in my sig). I wouldn't have a clue how to override the OEM immobilizer without having a mated ECU and FOB to swap into the vehicle. Of course, a laptop wouldn't be involved with that anyway.
Tech Info Resource
You would need to derive a sequence number from the certificate ECU that will be used next to generate the shared secret.
Someone has demonstrated cracking this system without a FOB? Or are they claiming they can scan the FOB and hack it? I'd really like to see it.
Ah - found this
Originally Posted by Factory Service Manual page EI-5
SYSTEM FUNCTION
(a) Using entry function
(1) When the driver (or passenger) is sitting in the vehicle while carrying the key, and the engine switch is pressed while the brake pedal is depressed, the power source control ECU recognizes that the engine start operation has occurred and sends a certification request signal to the certification ECU. Upon receipt of the
certification request signal, the certification ECU sends a request signal to the indoor electrical key oscillator. Upon receipt of the request signal, the indoor electrical key oscillator sends a request signal to detect if the key is inside the vehicle. When the key receives this request signal, it answers by sending an ID code containing a response code through the glass antenna to the door control receiver. Upon receipt of the ID code, the certification ECU analyzes the code. If the interior certification passes, then the power source control ECU sends a certification pass response signal.
