Blackberry Pearl Phonebook transfer to Parrot Bluetooth Kit
just installed the Parrot CK3200(Bluetooth kit) in my non-nav IS. i was wondering if anyone else has the/a Parrot kit, because i have no clue on how to transfer my phonebook from my Blackberry Pearl onto the CK3200.
if anyone with a BB Pearl know how to transfer phonebook/pics through bluetooth i could definitely use the help! lol...thanks guys
you may have to do it similar to the treo phones where you have to disconnect the phone from the unit and send your contacts to the unit via bluetooth. try that and see if it works. I've had a lot of customers with treos have a similar problem.
thanks cspec. yeah, i just had a Samsung A920 which was a decent phone too, but the pearl just has so much more stuff to you can do with it
hmm, never thought about trying that. i'm definitely giving that a shot today.
thanks 88supramki!
i'll let you know how it goes...
How do you like your Parrot BT system? How did the install go and did you use their direct wire harness?
Thinking about getting one and your the 1st person I've seen with one installed on their non-nav IS.
...but my car has NAV, but in order to transfer the phone book I had to disconnect the phone from th NAV system, then set the car to receive the phone book then transfer with the phone by going to the bluetooth section highlighting my IS on the bluetooth list, then going to options and transfer phone book....it only takes about 10 seconds for about 220 #'s!! Works perfect!!
To install the Parrot in an IS you just need a plug and play cable called a QCJBL-1 - see here www.parrotkits.com
