low tire press warning?
yep thats what I assumed... Either the warning light is on or all tires pass the check. But apparently something else is causing the warning because 40psi is plenty. I dont think my tires were even low to begin with. I usually run around 35 or so but when the light came on i put them all to 40
The car doesn't know where each sensor is by it self it has to be programmed. A programmer would let the computer know which tire has which sensor and once that sensor would sens a low pressure it would tell you which tire it is and what the pressure is, it's just that Lexus decided not to give us that option. A lot of the American cars that have sensors including Corvette tell you which tire has what pressure.
It knows which sensor has what pressure but doesn't know where it's located untill it is programmed. For example if you would put a front sensor in the back of the car without reprogramming it, the car would think that the sensor is still in the front of the car. Maybe I just explained it wrong in the previous post.
