low tire press warning?
As stated above check them all....this happened to me a week ago here in LA, but it was because the weather had changed dramatically from the 80's in the day to the 30's at night, so the air temperature had dropped the pressure pretty evenly on all the tires, I pumped them all up (while they were still cold) to the specified pressures, and like I said it's been a week, and I have had no more warnings.....
Tech Info Resource
It might. There are two receivers, and it isn't clear from the documentation if they are used for fault tolerance or for distinguishing the relative position of the wheel. (CONJECTURE- it could be done.) But there is nothing in the documentation saying they do anything other than identify by ID1, ID2, ID3, and ID4. Let's see if justfixit chimes in, he's forgotten more about this than any of us will ever know.
my tire pressure sensor light came on the other day so i checked all 4 tires and put 40psi into each, however the light is still on. I gotta take it to the dealer, i just havent had time yet. Anyone else have this problem?...
I've had the low tire press warning 3 times, in my experience if you fill to the correct pressure as soon as I turn my car on the warning went away.
