wire color from amp?
Could someone possible tell me what color wire is the Rear Rt/Rear Lt speaker wires. Or maybe even the input color. I am trying to run my sub amp off of these wires so any help is great. Thanks
-Dang
-Dang
do not be confused. just read through it. it is the whole schematic diagram for the audio/nav system.
Be sure to save this file... it will be very helpful for you.
btw.. what are you trying to add?
If you are planning to add a sub... you can use a line out converter right where the audio outputs from the amp in the trunk. No need to tap it from the sub. Just from the sub output will give you the same results and it will be a much cleaner install.
Already saved it. =D. I have plugged it to my factory sub wires, but i believe its pushing too much bass from it? What i did was cut a set of RCA wire and rewired it to the factory sub(pulled out my factory sub). So i really want to find the INPUT wires from the deck to the amp.
Frankdorn
05-28-10 10:26 AM
danger4o5
02-25-08 01:06 AM
Adam5oh
07-09-04 05:09 PM
SupraCoup3
24
03-05-04 08:23 PM
