rattle in rear deck
I'm getting a rattle in the rear deck whenever a play anything with any decent low end extension. Not rap or anything bloated like that, just some good o'l rock and roll that should be tight. Audio controls are flat except for bass being set to +2 or +1. Even dead flat it makes noise though. I can push down on the rear deck and it goes away. Anyone else have this issue or resolve it?
Thanks.
Thanks.
I have the same issue. I am in the works of Dynamat the entire car. Doors, deck, behind rear seat, trunk, & trunk floor.[IMG]
Check out my pictures.
http://www.clublexus.com/forums/show...hlight=dynamat
I have the same problem, too. Unfortunately, the tech at the dealer said he couldn't pinpoint the problem, so I guess I'll bring it up again at the next service appointment when I have to get a piece for the moon roof replaced because it was rattling as well.
Awesome job DJ. I don't have the guts to rip open my car yet
If I could find a good shop local I'd love to do that.
Maybe the dealer can do something during the next service.
I'm a littel discouraged. This is my first lexus, and first "luxury" car but the noisiest car I have owned. (not including engine noise from the Mach1, but that was a good thing)
Guys,
I have the same problem too. Cant seem to figure it out where it's coming from. I've taken it into the dealer 3 times to try to resolve it and they cant figure it out either. Seems like it's more present when the car has been in the sun for a while.
My findings on this issue is the back deck cover being too close to the rear deck itself - simply change the clearance by adding some insulation between the deck cover and the deck itself solves the issue - at least for me.
This is a common issue in most cars that have rear subs powerful enough to generate the force required to vibrate the deck cover.
Thanks.
Thanks.
The dealer seems to be a pretty good one and the noises are getting REALLY annoying. Picture driving down the road, you keep hearing a rattle to the left of the instrument cluster and eventually out of frustration you turn on a CD to drown out the noise.... and you just get another noise instead.
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
The only way out is to park the car and just sit in it. It is very quite then.
Bocatrip
07-02-10 03:09 PM
