Lexus ISx50 Front Spoiler Ground Effects Install DIY
Old 06-15-08, 08:40 AM
  #61
VikH
VikH's Avatar
Originally Posted by i3urton
yea i just got done installing mine and i have a lil gap where the 3m tape is... i can see the tape a lil if i stand directly on top and look down..
Does it look like the pictures in my first post? If so, they are not locked in properly. You shouldn't see ANY tape. Did you jack up the car? You need to pull on the bumper while pushing on the lip. Let me know if you can't get it to lock.
https://www.clublexus.com/forums/sho...&highlight=lip
Old 06-15-08, 09:27 AM
  #62
i3urton
i3urton's Avatar
no u cant see through it but u can see the tape..i think the tape bundle up... as i took off the cover.... thanks for the post ill probbly get red 3m automotive tape and reapply and try to pull the front out a bit...all my screw went in just not one of them....is there are particular brand of 3m tape i need "red one??" im new at this if u cant tell any help will be appreciated
Old 06-15-08, 11:18 AM
  #63
VikH
VikH's Avatar
I don't understand how it bundled up. Can you take a picture and post it? Also, the 3M tape is called 3M Molding Tape. It's for automotive applications. You should be able to find it at Autozone or any other auto shop. However, people have said adding extra tape can cause the gap to increase.
Old 06-15-08, 06:01 PM
  #64
i3urton
i3urton's Avatar
here it is.. the other side looks fine..but if u see u can see a lil tape..
http://img299.imageshack.us/my.php?image=img2173iy1.jpg
Old 06-15-08, 09:54 PM
  #65
VikH
VikH's Avatar
I can't really see anything wrong in the pic. Can you upload a bigger pic and a zoomed in picture?
Old 06-15-08, 11:52 PM
  #66
silversx
silversx's Avatar
did the install on friday.. friend pulled off those 4 metal tabs that came on the lip .. i guess for the drilling method..
took out 9 screws.. no tabs or clips i dont think.. and popped in the lip... put 9 screws back..
that was it..
Old 07-14-08, 09:46 PM
  #67
JensBoo
JensBoo's Avatar
We just installed mine. Best birthday gift ever! Got a new lip and a new coach purse
Thank you for the write up. Took a little teamwork, but we got it on with no gaps.
Old 09-26-08, 12:56 PM
  #68
saintsaens
saintsaens's Avatar
Default how the heck do you remove the c-clips?
hey guys,
stupid question but I'm one of the technically inept. I cannot for the life of me get the two c-clips out to install the GFX front. The other 9 screws come out easily enough but I'm afraid to snap off the clips if I put too much pressure.
What's the best way to do it?
Thanks.
Old 09-26-08, 01:41 PM
  #69
VikH
VikH's Avatar
The clip has 2 parts. The top and base. You need pull the top out (not off) using a flathead screw driver. Then pry off the whole clip. It should not take much force. If it does, stop because the top is not fully out. PM me if you still have trouble.
Old 09-26-08, 01:47 PM
  #70
XprincoX
XprincoX's Avatar
yea just stick a flathead screwdriver into the lil slit on the side to pop the middle up alil. Then you can just pull the rest of it out with your hand.
Old 06-08-09, 12:55 PM
  #71
bjechols
bjechols's Avatar
Super easy...can't beat $114 shipped for the lip and 10min worth of an install. Thanks for the write up. -b
Old 02-12-11, 05:25 PM
  #72
istundra
istundra's Avatar
bump for technique!!! your pix pulled through again!!! old skool DIY! much props!!
Old 02-14-11, 06:18 AM
  #73
Technique
Technique's Avatar
lol, good times
Old 01-16-14, 02:15 AM
  #74
Windaica
Windaica's Avatar
Doing it tmr "finger cross"
Old 05-05-15, 06:41 PM
  #75
dnwin
dnwin's Avatar
Trying to get the OEM lip!!! where could I get it for a decent price guys?? 08 is250
FUZCO
RC - 1st Gen (2015-present)
07-22-15 09:02 AM
ISAVY
02-27-10 03:14 PM
NYlexus
12-17-08 11:11 PM
mattssi
10-13-06 07:12 AM
bodyopus
07-02-02 09:16 PM
Quick Reply: Lexus ISx50 Front Spoiler Ground Effects Install DIY
