Help me out here, Key is not detected but the car drives OFF!
#31
Which would you prefer - car jacker pulls you out of car at gunpoint, then jumps in and the car dies right in front of you, or car jacker pulls you out of the car and drives away only for the car to be disabled for next start?
Sorry, I get the idea of having the engine die and at first glance it sounds like a good idea, but if you push the envelope just a little, you can see why they might have designed it the way they did.
But if you were jacked and you manage to put some distance between yourself and the car (out of range) if the car was shifted into gear after and didn't detect key, car disables. If it hears key when shifted as in you are outside the door sitting on the ground, let it go.
#32
My reason for mentioning it is people accustomed to key required ignition in the past may have stopped at an ATM or grocery, turned off the car leaving passengers sitting in it while driver ran a quick errand......remaining passengers--- one of which may have had an extra key but nobody could just jump in with passengers left in car, start it immediately and drive away with them in there as could be done now as long as any one passenger has an extra key FOB.
It is something to be aware of, that you must lock your passengers in the car if they are staying behind for any errand if one of them has also has a FOB.
#33
Originally Posted by kensteele
If you tried to lock the door with a passenger inside the car with a key FOB in his pocket (LOL LOL), you wouldn't be able to lock your door. If you leave your vehicle unlocked, you chances of theft rise. If you leave a key an unlocked car, even higher.
I didn't say it was a problem. I simply pointed out that some may consider the need to be sure and lock the car when exiting, e.g., if you are leaving passengers in it while running a quick errand if any one passenger has a key FOB.
#34
I get your point. Presumably only adults will carry a FOB, if driver leaves the vehicle, remaining passenger(s) should secure the vehicle by locking the doors, whether they have a FOB or not. Honestly, I think it's that simple. To me there's no difference between a stranger jumping in the car to rob the passengers or jumping in the car to steal the car.
It is something to be aware of, in old days with key required you could exit the car without worrying and leave windows down for air for remaining passengers even if one had an extra key, very difficult for anyone to get in and start and drive off.
Also, don't know if a trend or not, but I see young families more and more with either Mom or Dad in backseat adjacent to infants and toddlers, who may remain in the car with the kid while driver runs a quick errand.
#35
How many times were you pulled out of the car? And how many times someone drove off with a running car, Percentages are much higher for the running car.
#36
I am sure if you wait long enough the car will turn its self off. But i guess it depends how much gas you have in you tank.
#37
Too me it seems like such a simple solution. The after market has such solutions for decades. If you leave your car on and take your FOB with you the car should remain on. If it was in park and the FOB is out of range and an attempt was made to put it into gear, it should shut off. Just like after market remote start systems. If the a car jacker throws you out of the car, puts the car into gear and drives off with you holding the FOB, they will be allowed to do so since at the moment the car was put into gear the FOB was in range. As the car jacker drives away and out of range of the FOB, it will remain on until he stops, and/or puts the car into park. Once that occurs the car should die and no longer restart. Just like how anti car jacking after market devices work.
This covers all bases. Your life will not be in danger if a car jacker jacks you since they will be allowed to put distance between the two of you. If you run into a store with the engine on, nobody will be able to drive off with your car since the FOB is out of range and the engine will shut down once moved out of park. If you are driving, get mad and throw your FOB out the window the car will remain on and not shut down until you come to a stop and put the car in park. I really don't see what the OEM's can't implement simple solutions that the after market had for decades.
#38
Tech Info Resource
And even if the lawsuit is frivolous and thrown out, you still have to prepare to defend yourself and show up in court. It's an expense that's easier to design out of the product with a technical control.
#39
#40
#41
Thats exactly what i wanted. I hope i can hack into that to do something or ovverride the system, anyone want to help out with the research?
Or atleast point into the direction where to start?
#42
Think about it if the IS turn off itself when your Smart key is not in the car, what happen if you just wanna to open a door for your GF? Or open the trunk? Anyway this is reason why I can't install timer for the IS too...
#44
The person with the fob has to open the door. Once that first door is opened, there are two ways you can program it, open just that door, or all doors.
#45
Yesterday i wanted to see if i start the car and get out of the car, it will say the key is NOT detected!!!! But my friends sat down in car and drove off like nothing happend?!?!?!? Any suggestions?
My friend has a 2005 M5 and he has the same thing with the push start, he can leave the car on with the radio and engine running, the car will aslo say the key is not detected, but when i sit down and put it into gear or press gas it dies since there is no key detected. I thought we get the same in lexus?!?!
Any info on this?
Any info on this?
