Help me out here, Key is not detected but the car drives OFF!
Yesterday i wanted to see if i start the car and get out of the car, it will say the key is NOT detected!!!! But my friends sat down in car and drove off like nothing happend?!?!?!? Any suggestions?
My friend has a 2005 M5 and he has the same thing with the push start, he can leave the car on with the radio and engine running, the car will aslo say the key is not detected, but when i sit down and put it into gear or press gas it dies since there is no key detected. I thought we get the same in lexus?!?!
Any info on this?
Any info on this?
2IS OG
The system will not turn the car off if it doesn't detect the key. If you think about it, that's actually quite dangerous. Say the battery inside the fob dies (which will happen eventually) - how would you like to be driving when that happens? I know I wouldn't, and I wouldn't want that happening to anyone driving next to me either!
Javier
Javier
i have the feeling the m5 will not just cut off if someone throws the key out the window on the freeway. he said the car was in park and the gear was then shifted, maybe that's the answer.
thinking about it briefly, actually that's quite clever. i guess now people can warm up their cars in the winter by idling in the driveway. lexus is probably not going to do this because in most states, it is unlawful to leave an unattended car engine running.
There is good reason for the car to keep running if you get out. If it is cold, or hot, outside and you have your family with you and you stop to run into the Quickie Mart, or get gas you don't want the car to shut off as you walk away from it. The driver has the responsibility to treat the Smart Key system the same as the old style blade key; it's just a different format.
this is lexus = safety
Any info on this?
Any info on this?
Actually, typical Lexus design would shut the car down, open the doors and eject the people, shut the doors, and lock itself. Being able to walk away with key in pocket and not having the car do anything but just keep on running is quite un-Lexus.
Super Moderator
Add me to the list of people that think the engine should die if you try to shift the car out of park with the key out-of-range. (Even though it means you would have to hold the key next to the start button to shift out of park if the key fob battery were dead)
The reson why is because I go to the mountains alot and i leave the car parked, i love snow but i love to get in and warm up, when i leave my car running in Park mode with hand brake (leg brake) I expect someone who gets in not to drive off since the key is not detected, BMW has it so i dont think that lexus decided have more safety than bmw, I obviously dont think anyone will throw the key out of the window on the freeway. That is why I asked.
Plus i work on my other car alot in front of my house and always turn on the music in the lexus but dont want the battery to die and i keep it running, I honestly don't want somebody to drive off while i'm under the car-----the other car i'm working on.
#1 shouldnt be filling gas wheile car is running, FIRE possible.
#2 you've got to be kidding me on the Quickie Mart story, theres no way in HELL, i get out of ANY car and run into a store, Quickie Mart, etc.. and leave my car running, ESPECIALLY MY LEXUS, $40K ,dont tink toe !!!!!
anyhow...i would assume the car should turn off if the key is out of range and someone tries to take it out of park...that only make sense to do it that way....design flaw me thinks
2IS OG
Some of us may like the BMW method better, but just because the smart key system is not like that found in the BMW or designed around what you assume doesn't mean it's a design flaw - it's just different. If I left my car unattended while running and someone stole it, I wouldn't be blaming Lexus for their 'design flaw'...
Javier
Javier
Javier
Javier
