Center Console Aux Jack
Here's a shot of the wires in the compartment. It goes through the hole I drilled, under the gear shift console, and to the ashtray. If you guys are wondering why only two wires, the ones you see in the pic is the aux cable and power cable. I routed the antenna cable from the trunk, through the passenger side moldings, under the passenger seat, and through the side of the elbow compartment. There is a small gap you can push in and fish the antenna wire through. Then it joins the other wires under the gear shift console.
dude that looks sick. Do you have any pics of the ashtray assembly? When you take the assembly out does the 12V come out too? What is the velcro attached too? Is there something underneath? Thanks man looks good
Once you have the gear shift console off, you will see two screws holding the ashtray assembly. Simply remove them and the entire ashtray assembly comes off. The ashtray simply comes off by pushing( or pulling, I don't remember) a lever on the side. Once the ashtray is off, you can drill a hole on the underside where the ashtray would go. No, the 12V will come out with the entire assembly. You will have to unplug a connector (I think it's for the ashtray lights). The velcro is attached to the front side of the ashtray lid. I will be putting another velcro on the other side of the dock. There is nothing underneath, it's just resting on part of the assembly. If you think of a better idea, please let me know. But right now, it doesn't move around and it is acceptible.
