How to launch your 2IS?
#31
Forgot to add the part about the learning computer. If you're out there all day nailing your car to the floor, the car will soon learn that that's the way you like to drive it and will compensate by shifting more agressively and will have a more aggressive throttle input via the throttle servo. For the record, I rarely drive my car that way.
#32
#33
I have the BS's, REO50's
#34
#35
I also notice that you have the sport package. Is it possible that with the stiffer suspension you're not getting the weight transfer, and therefore, less traction?
#40
2IS OG
Javier
#41
Tech Info Resource
And it will shift at redline regardless of the ECT/snow switch position. I've proved this to myself a few times. Just be sure your floormat doesn't interfere with the accelerator's travel so you definitely hit WOT, and there will be no issues at all with full throttle acceleration.
FWIW, I raised my accelerator pedal about 1/2" to get it closer to the brake pedal height and ensure I will hit WOT when I mash on it.
