Which H.I.D kit should i ask santa for? Need Advice.
I was searching on ebay and they had these MTEC kits going for around 340 bucks. Are there any other kits out, and what place has the best prices for this unit? I would imagine ebay but you never know.
Also I'm debating between 6,000k and 8,000k. I don't want to get something illegal, i want something that looks like a stock hid kit, which is why i would imagine 6k would be better correct?
And lastly down the road i know eventually these bulbs will give out. Are the replacement blubs pricey?
I have 6000K Xenon Depot kit. They are a little more pricey than the MTEC kit but it seems like well worth it.
8000K is really blue. You might get pulled over for that. I used to have 8000k MTEC kit when i had my RSX and I was happy with it as well.
I know many people out there have done it, but I still want to give out an honest advice.... putting a "HID kit" in a projector or housing that is originally designed for halogen bulb is a bad idea. If you look closely on the same car model, but one with OEM HID, one with OEM halogen, you can easily see that the projectors are different.
If you want to do it right, you really need a retrofit with shroud to confine the light and to give a clean cutoff. Otherwise it would have a lot of glare, and that glare is what blinding the on-coming traffic and create blurry visibility to yourself. It's a safety issue.
This website offers retrofit service:
www.customlightz.com
They worked on one of my cars and the result is fantastic.
Xenon depot kit is definitely a quality kit. The only problem i have with it is the crappy connector they use for the ignitors. You'll need to mess with it a bit to get it to stay connected. Otherwise, the kit is great.
Pleeeease don't take my comment in an offensive way.....
The thread starter still has the freedom to go with a simple HID kit. I just wanted to point out that there are options out there that would do it the right way, but a bit more expensive of course.
You are not the first person to say that. But unfortunately, "light" is a very hard subject to debate and even photos are hard to do justice. But the fact is that, the light is not confined with the halogen projectors without a shroud, and I guess that's what you referred to as "rare light pattern".
The thread starter still has the freedom to go with a simple HID kit. I just wanted to point out that there are options out there that would do it the right way, but a bit more expensive of course.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
For Custom Lightz, you can pick and choose a projector and shroud from A4/S4, S2000, TSX, M3, Porsche (Hella) bixenon, E55 bixenon, TL bixenon or custom made shroud, each would give a different appearance.
You can talk to a guy named Bjorn and mentioned that Wai with a Spoon race car referred you to them, they would give out referral discounts. Good luck!
I had the MTEC 4500 lights in my last IS.
They were awesome. The light was white, without any/much yellow. And it was bright... real bright. The bad news is, my GF complained that my lights were blinding, when I followed her.
I probably should have just adjusted them lower. My new IS with the AFS HIDs... just dont seem that bright to me.
