Opinion on what wheels to get
Have opportunity to get ISPs/tires as a swap for my stockers for 1300. Yet I also like the Work Euroline FEs in 19s (3500 w/tires). Will the stock ISPs with the 225/255-40 tires ride smoother than the 275/30&235/35-19s?
If you go with the 19"s, see if you can go with 265/35/19's in the rear. The 275/30's are smaller than stock (and the 235/35/19"s are larger than stock.)
This will have a couple of negative consequences:
1. You're reducing the stock stagger (in terms of overall diameter) front to rear.
2. You're increasing the stock stagger (in terms of the width differential) front to rear.
The former may affect the vdim, vsc, abs, etc... The latter will increase your cars tendency to understeer, which will add to the tendency built in from the factory.
Answer
06-27-15 12:34 PM
