LED Flasher
Old 11-14-08, 11:44 PM
  #76
MRTUND350
MRTUND350's Avatar
The front takes two 7440 amber bulbs on each side so 4 total. You need an bulb with radial firing LEDS because the sit vertically in the housing. Also you need to take off the front bumper to get to them, also you don't have to but it makes it easier to remove the drivers side headlight, there is one that is a real bugger to get at.
Old 04-08-09, 02:22 PM
  #77
Dj_AmtraX
Dj_AmtraX's Avatar
I did it here. Flasher doesn't hyper flash, but killed my stock alarm arm/disarm flashes.
https://www.clublexus.com/forums/is-...-dyi-pics.html
Old 04-08-09, 03:07 PM
  #78
ABC
ABC's Avatar
I can't believe it took that much work to change turn signal lights... if mine blow out, i'm just selling the car. less effort that way
Old 04-08-09, 08:23 PM
  #79
eskae3
eskae3's Avatar
DaBigMan,
Do your lights flash to confirm that you lock or unlock your doors? Btw, the front headlight removal isn't too bad. Can be done in about 1 to 2 hours.
Old 04-08-09, 09:57 PM
  #80
ankurman20
ankurman20's Avatar
anyone changed the reverse lights to LEDs? Any problems?
I have led reverse lights and havent had a problem yet... just pure brightness
Originally Posted by cdeslandes
I installed LED flashers in the back. Got them at superbrightleds.com. Instead of changing the flasher, I just installed resistors. Taped them to the body for heat dissipation, just below the light clusters, hidden behind the trunk trim.
I did the same thing
Old 04-09-09, 06:28 AM
  #81
acefalcon2
acefalcon2's Avatar
the reverse lights won't have any problems as it is a consistent voltage
Old 10-15-09, 09:37 AM
  #82
Dj_AmtraX
Dj_AmtraX's Avatar
Anyone found a flasher that will also fix the alarm on/off confirmation blinks? The flasher I am using fixed hyper flash but killed alarm blinks.
s6 4rings
11-10-13 11:43 PM
Justinkm
04-22-11 01:36 PM
svagusta
Lighting
10-26-10 07:26 PM
Quick Reply: LED Flasher
