Road&Track:1. IS 350 2. TL Type-S 3. G35 Sport (merged threads)
#182
ECU timings and the engine tuning may have been changed, and that is not something which would be readily apparent.
#183
Tech Info Resource
Here's a list of everything Lexus thinks is worth mentioning for changes from '06 to '07. The 21st item you can't see is the appendix. Maybe the big difference is they weren't on a slippery surface this time...
#184
The reason for the disparity is probably because with the 2007 you can turn off traction control and computer input with a switch, which they did for this test. The test of the 2006 probably had all that stuff on.
#185
Tech Info Resource
You can turn off TRAC on the '06 with a switch, and it will aid launch control if you want some slip. Good point though, they may have completely ignored it the first time.
#186
#187
Tech Info Resource
If you're slipping after 25 mph, you're on some bad pavement or you're doing an intentional burn out.
#189
Just for fun,
Road and Track tested BMW 335i in this month issue and they could "only" get 5 sec flat for 0-60 time. OH MY GOD, that's like .1 sec SLOWER than IS350 they tested.
0606, 2006, 454, clutchpersonal, consideration, es330, function, g35, is350, performancecompute, seconds, sport, squeeze, suspension, tight, tuned, vsg35
