Running Wires Out of the Glove Box?
Has anyone run wires out of the glove box to the center console behind the HU? I want to put my ps2 in the glove box since it fits perfectly there, but there seems to be no opening and i don't want to drill.
Thanks for the help!
TJ
TJ
i can just sit the ps2 on the shelf thing where the manual would normally go and when i need to change the cabin filter i'll just remove the ps2, it's just the power plug and a/v connection.
where else would you recommend me putting it? i'm open to ideas i just like the glove box cause its fits well and easy access.
istundra- can you check out the pics below? i'm pretty sure that hole passes through behind the HU. so when i remove the HU to do the hack i should be able to access it fine, right? thanks for the help! i just want to plan it out beforehand and i know you've pulled out the HU before.
![](http://www.teejnut.com/public/TJ/IMG_3067.JPG)
![](http://www.teejnut.com/public/TJ/IMG_3068.JPG)
also anyone know whats behind the plastic piece on top?
