Headlight Adjustment Success!
Old 07-12-15, 10:47 AM
  #136
Aversed
Aversed's Avatar
Sorry to bring this from the dead, but can anyone upload the pictures again? I've been trying to look for the horizontal hole for the longest time, and I can't for the life of me find it. I've looked on multiple forums for pictures, but nothing. I adjusted the visible screw already.
I have a non-HID 2007.
Old 11-02-15, 06:20 PM
  #137
videopho
videopho's Avatar
Mine is 2007 and the manual is not even close or borderline useless.
Anyone with 2007 please chime in.
Old 11-09-15, 06:17 AM
  #138
mrredpants
10th Gear
mrredpants's Avatar
Here is the video I made a while back for the 2007 - mine IS HID
The following 3 users liked this post by mrredpants:
bryan11 (08-01-23), lttlLater (05-08-20), ncatona (12-05-21)
Old 11-09-15, 05:45 PM
  #139
videopho
videopho's Avatar
Oh yeah this is what I found a couple of days ago on-line and it helped out quite a bit. Thanks
Old 11-29-15, 09:12 AM
  #140
videopho
videopho's Avatar
Mine is 1007 and the horizontal adjustment screw does not seem to exist as claimed by several members.
I may try to adjust the vertical again as it seems a little low still.
Old 09-03-17, 10:51 AM
  #141
IS220Deu
IS220Deu's Avatar
Reviving this from the dead.
I have an 07 IS220d with stock projector halogens and paid 12$ to have the dealer adjust the headlights.
I can confirm that the factory spec height is too low and I can barely see past the 50m mark whereas with my other car, a Peugeot 308 with reflector halogens, I can see much further and much wider.
I can also guarantee that the projector halogens do not have an horizontal screw since that's a xenon only feature.
ncatona (12-05-21)
Old 09-04-17, 01:27 PM
  #142
bazzle01
bazzle01's Avatar
Attached Thumbnails Headlight Adjustment Success!-20170324_080522-medium_zpsrjlerckj.jpg   Headlight Adjustment Success!-housing.jpg   Headlight Adjustment Success!-halogen.png   Headlight Adjustment Success!-hid.png
The following 2 users liked this post by bazzle01:
Old 05-08-20, 12:45 AM
  #143
lttlLater
lttlLater's Avatar
Thanks for the nice picture!
Old 05-08-20, 12:52 AM
  #144
lttlLater
lttlLater's Avatar
Great video! Thanks!
Old 11-14-20, 10:44 PM
  #145
SteelBird
SteelBird's Avatar
I didn't count the teeth or how many turn of the screw driver, I simply face my car to a wall and adjust the headlights until it satisfy me. I did it vertically only and found my car's headlights a bit leaning towards the right. I will adjust the horizontal later.
Old 09-30-21, 12:08 PM
  #146
mkazemba
mkazemba's Avatar
Default HIDs without AFS
I have a 2007 IS250. I know it has HIDs, but I don't know if it has AFS. I don't have the car near me, so I can't go through the menu to see if there is an AFS switch. If the lights move up when I turn on the car, however, does that mean I have AFS? I believe the lights move when I turn on the car.
Old 03-23-22, 05:07 AM
  #147
SilvaLex11
SilvaLex11's Avatar
Default Headlights Auto sensor levels
Hi guys,
Please help, I lowered my car on BC coilovers and and now I'm getting a warning message on dash saying check headlights. The car is not that low I only lowered it about 10mm from standard is350 F sport specs.
I do have to level adjustments I noticed one behind the rear passenger wheel and one in the front passenger side.
No matter what I did and how I adjust it the warning lights won't go away.
I took it to Lexus and they said they don't know what's wrong with it unless I pay about $1000 and leave the car with them for a couple of days.
Can anyone help please, there has to be way
Old 03-23-22, 07:50 AM
  #148
MikeFig82
MikeFig82's Avatar
Originally Posted by SilvaLex11
Hi guys,
Did you see the steps in these threads?
I'm assuming that by lowering it. The sensors lost the 0 point.
https://www.clublexus.com/forums/is-...fs-sensor.html
https://www.clublexus.com/how-tos/a/...springs-362554
Old 03-23-22, 12:56 PM
  #149
SilvaLex11
SilvaLex11's Avatar
​​​​​​Thanks for your reply, yes no mater where I adjust it to its still showing the warning lights on dash, I can tell the ads still working as I turn the car on off the lights go up and down but I get a message saying check headlight warning
Old 03-23-22, 02:32 PM
  #150
MikeFig82
MikeFig82's Avatar
Best advice I can give for this is try this first.
Read post #4. The members mention starting on the rear sensor first. Remember your car is now lowered so bring the rear down some. Can you see the existing indention of the bolt head on the level arm? If still visible I'd start there. Unbolt the arms and hand tight back to fixed position. Then do what is mentioned in the post. If everything goes well secure the arm bolts back correctly.
https://www.my.is/threads/headlight-...-is-on.418991/
Quick Reply: Headlight Adjustment Success!
