Headlight Adjustment Success!
#48
So I finally adjusted my lights. For those with the AFS system, you HAVE to adjust the horizontal adjustment the same amount of turns as the vertical. When I was adjusting the vertical, you can clearly see the horizontal beam move. I placed a couple of markers on the wall before I started adjusting them.
How much of a difference was it? About the same as the vertical change?
I'll take a look this weekend when I go to the garage and park the car 30 feet from a wall and see if my lights appear to be pointing left/right instead of straight ahead, but they seem to be fine... They are a pretty wide beam anyway, maybe that's why I didn't notice in the first place...
#50
mooncake master
Hmmm, I didn't notice a movement in the horizontal, but I didn't mark the wall, just eyeballed it...
It's basically on the fenders, it's only a couple of inches from the vertical adjustment under the black plastic liner that covers the fender. It's a hole just big enough for a long screw driver.
#53
Well I did this adjustment recently with 50 notches upwards both vertically and horizontally. However, I noticed that my left headlamp beam is not perfectly flat. The right side of the beam is a little higher. This is not a gradual increase, but an abrupt right angle increase. Is this normal?
#54
this might be a dumb question, but what's the recommended height level you should have your lights set to? should the top of the beam be "x" amount of inches from the ground?
#55
#56
#57
Thanks for getting back to me. I figured it was normal. Now I have to figure out if I am blinding people or not. I think nowadays people are used to super bright headlights, so even if they are blinding people won't let you know (ie flash you). The Acura headlights are pretty bright. I don't think they have an auto-leveling function which makes it worse.
#58
My old Acura CL Type S's headlights were definitely higher, and with no auto leveling, they would shine very high at times!
#60
Best way to check is to simply see where your headlights come up to on the trunk/trunk lid of the cars in front of you... When you're about 10-25 feet away, see if it's above the trunk lid, if so, they are too high for sure... Mine are about 6-12 inches below most passenger car's trunk lids...
looks like we both stepped up from acura cl-s... yea the headlights were higher, acura seems like they have prefected their headlights
