But on Carista's own site, it says Carista doesn't support the 2010 IS250. If Carista doesn't work any longer, is there something besides Carista that will work with a normal ODB2 cable?
I picked up Carista but had to return it, it works but very few options for my 2016 IS200T, funny thing you can program to open your windows with the remote but not to close them.
Carista eh?
Hmmm. I'd really like to change the climate control to stop engaging "recirc" mode when I turn the temp down.
Damn annoying!
Also, are there any free apps avail? Seems silly to have to purchase these goofy things just to change settings on your car!
Most require the Lexus "intelligent tester" to change, so you need to go to the dealership. Some can be done without it, those items have a comment above them about seeing your owner's manual.
Thanks Lobuxracer. I changed the battery today. 12 years on original battery was a good run. It was still good, starts good, but if you don't drive it for a day or two, it drags on that first couple turns. So, as you probably know, 'Winter is coming' . NAPA Legend, AGM battery for the ' win'.
I kept the original 'made in Japan' Panasonic battery. Traded in an old marine battery for core. You can see the water level on the side of that battery.
Damn thing lost its personal settings. Frikken radio remembered its setting and clock. I connected the battery charger to battery cables and ground, and it still lost all of its settings, Annoying. Reset the tack and speedometer 'yellow' warning, but its chimes again if you unlatch the seatbelt, while driving.
so I have that to go through again. Thanks for the PDF list
Thanks
Old grey,
